Old 11-20-2007, 09:47 AM
WilliamD is on a distinguished road
Lathe belt help needed...
I have acquired a Logan Lathe model 922. I am fixing it up and have nearly completed it. The last issue is it came with an old 1 inch wide flat leather belt to power the headstock. I was hoping to swap out the two step pulleys with v-groove pulleys, but the bore on the headstock is too large, and I can't find a step pulley that would work.
So my option is to find a new belt. I looked on sdp-si, but couldn't find what I was looking for. I'm hoping the greater wisdom of the forum will point out my ignorance and I can finish this project.
I looked on McMaster for step pulleys, but the largest bore they had was .75". Anywhere else I should be looking?
Thanks in advance!
Old 11-20-2007, 09:50 AM
Also, I temporarily have a link belt on there, but the power transfer is not very good. If the lathe bogs down at all, the belt slips. But at least I can see it run. This is my first lathe, and I look forward to posting all the pics and using it when I'm done.
Old 11-20-2007, 10:55 AM
djr76's Avatar
djr76 is on a distinguished road
Buy a pulley with a big enough hub and bore it out to the size you need.
Old 11-21-2007, 06:25 PM
Thanks for the advice. Luckily I was able to find Loganlathe.com, and they have all the replacement parts I need for the lathe. They have some urethane belts that would be a bit better, so I'll order one of those. Although, they are not cheap!
Old 11-21-2007, 06:43 PM
ajdcnc is on a distinguished road
Hi everyone in CNCZone. I have the silly question that artcam can generate toolpath for 2 Axis lathe?Thanks
Old 11-22-2007, 11:39 AM
Bear is on a distinguished road
Hey ajdcnc,
a silly answer would be,
they specilize in 3 axs lathe
Bear
Some advice needed on X-Axis belt issues. kumaichi Industrial Hobbies (Support forum) 14 02-21-2007 08:47 AM
belt numbers for 6" Craftsman Lathe? shootingarts General Metal Working Machines 2 02-08-2006 08:29 PM
Belt Drive - advice needed Pat2000 Linear and Rotary Motion 11 11-01-2005 08:11 AM
Hardinge Lathe Spindle Belt change Ken_Shea Bridgeport and Hardinge Mills 0 09-12-2005 01:39 PM
Belt size - help needed Moondog DIY-CNC Router Table Machines 3 08-09-2004 06:56 PM
