Old 11-19-2007, 02:29 PM
Candell is on a distinguished road
Need some help
I'm looking for a mini-lathe or a bench-top lathe (are they the same thing? ) that will suit my needs. I'm interested in a lathe that is not too expensive but is also rigid and durable.
I'll be cutting titanium, aluminium and maybe stainless steel. Do all lathes come with the capability of threading? If not then that will be one of the requirements.
Please note: I'm new to metal work and machining. Pardon my lack of knowledge or ignorance.
Old 11-20-2007, 08:44 PM
g-codeguy is on a distinguished road
Hi, Candell. Did you try posting this in the hobby section. I know a fair amount about full size CNC lathes, but nothing about the hobby ones. Stick with aluminum for all the jobs you can on such a small machine. If you need to cut stainless, take very light cuts...probably you will also need a slow feed. Run 303 or 416 stainless (preferably 416L) if possible.
Titanium is soft and gummy. At least the grades I have run are. Turning with oil seems to be fairly easy. Use a slow SFM, tho. Be careful drilling. You can burn them up in a hurry if not running the correct SFM and feed rate. Course that could be said about almost any material, but I've found it to be nasty material for drilling. Again that is just my experience. Others may have a different opinion.
Old 11-22-2007, 02:11 AM
Paul_S's Avatar
Paul_S is on a distinguished road
If you machine titanium make sure you have a class D fire extinguisher. Standard A, B & C extiguishers would only supply more oxygen in the event of a chip fire. Titanium can burn like magnesium which also requires a class D extinguisher handy.
Safety - Quality - Production.
