Old 11-19-2007, 10:43 AM
petriej is on a distinguished road
Tapping 4-40 on CNC
I have posted regarding this subject before, but I would like to know what tool holder shops are using to form tap 4-40 in 6061. I have done quite a bit of research, but can't pinpoint which holder would be the best for this application. Or should I run solid with a collet? My machine is older, but does have the tapping autocycle.
Any help is greatly appreciated.
Thank you
Star SR20RII/Fanuc 18i, DMG CTX310V4/Fanuc 32i, DMG CTX310ECO/Siemens 8400, Mori NV5000/MAPS, Bridgeport 760/Fanuc 18i, Kiamaster 4NEII60/Fanuc 3t;Partmaker, Gibbscam
Old 11-19-2007, 12:01 PM
djr76's Avatar
djr76 is on a distinguished road
I use a rigid tap holder with quick change tap adapters for each size of tap. Any collet should work as well though.
Old 11-19-2007, 02:41 PM
star-turn is on a distinguished road
Depending on how used your m/c is and whether it supports rigid tapping i would go for a 'floating' holder - one that lets the tap either pull out or compress - you will have more control over getting the tap to cut without snapping.
PCM do a nice version that fits directly into an ER25 collet holder.
ST
What exactly is Rigid tapping? Why people always ask does it do rigid tapping? cjchands General Metalwork Discussion 23 12-19-2008 08:19 AM
Tapping on a TL-2 rbest27 Haas Mills 11 12-01-2007 05:47 PM
Rigid tapping or tapping head wildcat Industrial Hobbies (Support forum) 7 09-24-2006 12:08 PM
Tapping 303 S.s. drill General Metalwork Discussion 3 02-03-2006 08:23 PM
tapping head vs hand/cordless tapping machine.... InspirationTool General Metal Working Machines 6 09-12-2005 08:10 PM
