Old 11-17-2007, 01:34 PM
guru_florida's Avatar
guru_florida is on a distinguished road
To Gantry or not to Gantry
I am planning a cnc mill design. I am wondering what the advantages/disadvantages are between a gantry mill and a "static Z axis"/"moving table" mill, (not sure what to call the later.)
It seems that the the Gantry would typically have a larger usable table area than a static Z design using the same length parts. However, the gantry has a large moment to consider since the leadscrew is often below the table. Though it could be moved above the table in a dual screw design, but expensive.
What other things should I consider?
Thanks,
Colin
Old 11-17-2007, 01:47 PM
svenakela is on a distinguished road
Search the forum and you shall find:
http://www.cnczone.com/forums/showthread.php?t=20109
http://www.cnczone.com/forums/showthread.php?t=4646
http://www.cnczone.com/forums/archiv...hp/t-4154.html
Goggle will help you a lot, for example Like this
Regards,
Sven
Old 11-18-2007, 11:55 AM
Thank you, reading all that answered all my questions...now still to decide which way to go. I think I am leaning toward moving table...I only want a small table for precision milling of robotic parts and pcbs. The large cnc machine I already knew would be moving gantry. It's big at about 3 feet by 6, but its only cutting/shaping foam and maybe light wood.
Gantry alexis221 DIY-CNC Router Table Machines 4 11-10-2007 09:17 AM
heavy gantry drafterman JGRO Router Table Design 6 11-07-2007 10:59 AM
gantry posix Linear and Rotary Motion 0 01-14-2006 04:57 AM
gantry MBG General Metalwork Discussion 5 08-17-2005 07:53 PM
