Old 11-16-2007, 04:38 PM
Paragon36 is on a distinguished road
Connecting Arc Welders in parallel?
Hello...
Is it possible to connect the outputs of two arc welders in parallel so as to gain higher current output or duty cycle?
I am thinking of the general arc welders purchased from a general store with a rating of around 200 amps each max.
SRG
Old 11-16-2007, 05:48 PM
DSL PWR is on a distinguished road
That should work well.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 11-16-2007, 06:04 PM
Thanks DSL_PWR :-)
Old 11-16-2007, 06:31 PM
Al_The_Man's Avatar
You did not specify what type of welder AC/DC SMAW, MIG etc?
The power supply characteristics of these are very different, e.g. SMAW relies on voltage collapse to guarantee constant current, as opposed to MIG which possesses constant voltage.
Old 11-16-2007, 06:58 PM
The welders I am interested in are like these ...
Not sure what they are AC / DC etc etc.
http://www.worldofpower.co.uk/acatalog/arc_welding.html
Cheers
SRG
Old 11-16-2007, 07:08 PM
Al_The_Man's Avatar
They look like a mixed bag, it is hard to tell as the specs are a bit thin on the ground!
They mention stick and wire feed, but not definitively AC or DC.
Chinese Welders Degrom Welding, Brazing, Soldering, Sealing 31 06-20-2009 09:53 AM
Any other Laser Welders here? Laser Pro Welding, Brazing, Soldering, Sealing 5 03-04-2008 09:27 PM
Connecting 2 steppers in parallel salvaCNC CNC Wire Foam Cutter Machines 2 09-28-2007 06:42 PM
A tale of two welders AtomicBeaker Welding, Brazing, Soldering, Sealing 11 06-22-2006 08:50 PM
Anyone with experience in Electron Beam welders DareBee Welding, Brazing, Soldering, Sealing 0 02-01-2006 08:04 AM
