Old 11-16-2007, 11:25 AM
pkalag is on a distinguished road
Super Spacer or Rotary Table w/chuck?
Looking for advice on which would be the best:
6" Super Spacer ex. Enco 202-3012
http://www.use-enco.com/CGI/INPDFF?P...TEM=RN202-3012
Or a 6" H/V Rotary Table w/ lathe chuck and adapter plate?
I machine mostly UHMW 4" OD round stock for wheel adapters on all terrain power wheelchairs. I have been out sourcing these parts but would like to cut them myself on my mill.
An advice would be great, also sources for either
Thanks PaulK
Old 11-16-2007, 05:10 PM
Paul, Do you want to index to incremental spacing or to any spot on the total rotation? Indexers do just that, index to discrete positions like every 5 degrees or what ever their spacing is set for. For example, a 5 degree indexer will not let you index to 22 degrees but would do 20 or 25 degrees.
A rotary table equipped with the correct scale will do 22 deg., 30 min. and may even divide into arc seconds. I guess it's what your needs are will determine which is correct for the job.
DZASTR
Old 11-16-2007, 06:14 PM
Thanks Richard,
I would like both incremental and any degree (but less necessary). I found originally when I used a Horz. rotary table and chuck repeating the bolt circle and slots to interlock the adapter to the purchased wheel hubs very time consuming.
Now the wheel hubs are continuosly changing and I also want to cut sprockets for developement purposes.
I guess the super spacer with the 10 sec vernier dial and 90:1 disengaging handwheel gets me the best of both worlds. ??
Still trying to learn how to produce round parts on a mill.
Any Pro's & con's going with this method?
Thanks PaulK
Old 11-16-2007, 09:42 PM
Paul, That "super spacer" sounds like a dividing head from a milling machine. These are a little cumbersome but usually accurate and versatile. Well suited for one-off's and low quantity runs but not for high production.
Good Luck
DZASTR
What 3 jaw chuck for a 165 rotary table? nervis1 Fadal 15 11-14-2008 03:29 PM
mounting chuck to rotary table? dahui Shopmaster/Shoptask 7 05-19-2006 10:56 PM
rotary table chuck senor J. General Metalwork Discussion 2 12-15-2004 03:21 AM
chuck for rotary table replicapro General Metalwork Discussion 2 11-08-2004 08:47 AM
Make a rotary table into a 4 jaw chuck replicapro General Metal Working Machines 3 08-28-2004 09:56 PM
