Old 11-15-2007, 03:14 PM
Shepard is on a distinguished road
Newbie question- Why fast spindles in Al?
Sorry for the newbie question. I see machines with spindles running 6k-15k
in conversations about milling aluminum. Could someone tell me what the real world cutting difference would be between say a 3k spindle and one of the fast ones? I mean as far as depth of cut and feedrate. Thanks for your time, Shepard
Old 11-15-2007, 03:54 PM
keebler303 is on a distinguished road
Aluminum likes high surface speeds with modern coated carbide tooling. In a hobby setting, most cutters used are small, so it takes high speed to get the desired surface speed (speed of the outside radius of the tool, generally in ft/min). In an industrial setting, time is money. You can take the same amount per tooth on the cutter, but if you run the cutter 4 times as fast, you are removing 4 times the material. Depth of cut and feed per tooth are similar, but the feedrate is much faster on a high speed spindle so that each tooth still takes the same size bite.
Clear as mud?
Matt
Old 11-15-2007, 08:37 PM
Thanks for the information. I am still struggling with calculating cutting speeds.
Old 01-04-2009, 02:03 PM
chrbau is on a distinguished road
Struggle
Try this free software:
http://www.colinusher.info/Software/...Utilities.html
It has feed speed calculator and a bunch of other useful info.
Another favourite is the "CNC Master Utilities" from:
http://www.colinusher.info/Software/index.html
Same price (free) and does a whole bunch of the most usual operations if you have a machine driven by the printerport. Holes on PCD, array of holes, square holes, chuck parts....
Realy good!
newbie question ? colka Stepper Motors and Drives 3 08-18-2007 08:09 AM
Yet another newbie question alexis221 DIY-CNC Router Table Machines 2 02-03-2007 04:30 PM
newbie question pinkerton5 General Metalwork Discussion 3 12-12-2005 07:27 PM
DIY CNC (question from a newbie) Sharx DIY-CNC Router Table Machines 2 09-13-2005 03:21 PM
