Old 06-12-2004, 12:48 PM
gtslabs is on a distinguished road
Grinder CNC Conversion
I have a 612 Boyar Schultz manual Surface Grinder. I am routinely grinding parts 2" in diameter, so my travel is not much. I want to automate the X and Y axis. Would adding stepper motors be the easiest route to go? If so, how do I size my motors? Would I need to determine the required torque to turn the wheels?
Since I don't need dead on accuracy for these axis I believe steppers would be better over servos. I have not done any cnc work before but have been reading these threads. Would I need to create some sort of loop that the gcode would follow that would cover my 2" diameter work piece? Then add a home position for when I want to replace my workpiece.
This is how I envision things working. Is this realistic? Can I get some recommendations on motors, drivers, etc...
Steve
Old 06-12-2004, 01:33 PM
Al_The_Man's Avatar
I assume you just want a controlled feed in the X with a prgrammed step-over in the Y etc, non-interpolated moves.
For these 'Simple' applications I still use a very usefull product that Galil brought out several years ago called Opint (operator interface) for the now legacy cards DMC600 & DMC1000, you can pick these up for very cheap on ebay.
The software was a one-time buy and you just need a Pal key from Galil for around $200.00 for which they still supply.
It runs under DOS and you can make very nice screens up. I have used it for point-to-point mills, brake & shear back gauges and a 3 axis cnc line punch. They no longer sell or support the software so I imagine I could sell a copy if needed. (the manuals need to be reproduced).
Al
Building CNC Surface grinder - whole lotta questions rashid11 General Metal Working Machines 6 03-09-2006 02:53 PM
Pics of my RF45 clone cnc conversion with flood coolant CNCPlastic Knee Vertical Mills 9 01-26-2005 02:02 PM
Gorton P1-2 + Sherline CNC mill conversion. jaydee116 Vertical Mill, Lathe Project Log 2 12-11-2004 11:10 PM
First Impressions for CNC mini mill conversion CNCadmin General Metal Working Machines 4 11-16-2004 08:37 PM
possible cnc conversion on homier mini mill WsW-WYATT Benchtop Machines 3 03-27-2004 07:24 AM
