Old 11-11-2007, 09:57 PM
RedDog22 is on a distinguished road
Lathe Auto Turret Design WIP
Hey all. Finished getting the basics of my auto tool post done in SolidWorks and would love some comments. Its not done. Nothing has its final dimensions buts its plenty good enough to understand theory. It will be used for a custom CNC mini lathe I will also be designing. One thing at a time though! Used hirth couplings as its locking mechanism but anything similar could be used in its place. Only thing not seen is where the stepper motor will mount or the clearance for the belt. Let me know what you guys think. =)
Thanks a lot. Enjoy the photo's.
ID:	46634   Click image for larger version
ID:	46635   Click image for larger version
ID:	46636   Click image for larger version
Old 11-12-2007, 03:19 PM
Guldberg is on a distinguished road
I like your idea of pushing back the hirth coupling instead of using pins and holes in the "head" for alignment. Ive been working on a turret myself, and i see the aligment as a problem in the machining. Only problem i can see is that, depending on the force the axes maybe due to torque, but if is for a small lathe there is proberly no problem there
Old 11-12-2007, 03:47 PM
phomann's Avatar
phomann is on a distinguished road
I'm not sure how you plan to control the turret from software, Mach3? I done a few turret controllers using the ModIO I've designed and sell. I'd be happy to work with you on the controller side if you need help in that area.
BTW nice design. What actuators are you planning to use to operate the mechanism?
Cheers,
Peter.
Homann Designs - http://www.homanndesigns.com
Old 11-15-2007, 11:52 AM
Sorry for taking so long to respond. I gotta agree the spindle probably cant take the torque from the tooling. I'll beef it up a bit more on this next revision. I need to calculate how much force will be at the cutter then I'll put it into COSMOS and see just how much deflection we'll really get. I'm guessing things will be fine!
Yeah I plan to control everything in Mach. Board wise I haven't really picked it out. Thanks for the offer. I may take you up on it. Though it wont be for some time. I had originally planned to use a mini solenoid to run a 3-way valve but have since moved to an actuator to run the 3-way valve. I'll post up a quick draft of how it would work. Need a few minutes!
Old 11-15-2007, 12:28 PM
Here's the 3 way and how the hose will be connected. An actuator will be attached to the piston. Stroke will be short. Around 10-15mm. I haven't looked at any specific actuators yet.
Old 11-15-2007, 01:46 PM
Is it a valve? Cant you just buy one, looks timeconsuming to make
Old 11-15-2007, 01:54 PM
Its not too time consuming to make but yes they can be bought, and will. I'll be looking for a magnetic actuator so I don't have to run air lines to both the 3 way and the actuator.
Next thing I need to do is get the tool holders drawn up.
Old 11-17-2007, 08:13 PM
Larken is on a distinguished road
There is too much mass and too small a pulley for a steppermotor to turn that.
I has that problem turning a carosel on our 12 tool toochanger on our routers.
Your locking design doesn't look strong enough, it should be locking at near the diameter of the turret.
A heavy metal dog may do the trick.
Old 11-25-2007, 04:50 PM
I'm very sorry guys. I haven't finished yet. I'm in the middle of moving toa new house so things are scrambled. Larken. Thanks very much for the comments.
Old 11-25-2007, 06:17 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
Yours looks similar this one, I built one of these and it does work very well
http://www.cnc-projects.de/
  #11   Ban this user!
Old 11-27-2007, 02:23 PM
Originally that was the tool changer I was going to make. But after going through all the draws I figured there had to be a simpler way. And my design...at least I think... is much less complicated. The couplings can be bought. And indexing accuracy can be as high as you want to spend the money on. Theres 21 unique parts on the German tool changer and many multiples. This design only has 13(not including o-rings, screws, or pneumatic parts) and the only multiple parts are the bearings.
Should be a great little tool changer once its done! Cant wait to get more work done on it.
  #12   Ban this user!
Old 12-05-2007, 05:06 PM
Got a better picture ?? Can't see much.
Lathe auto-turret project log kong Vertical Mill, Lathe Project Log 74 04-08-2012 11:16 PM
Converting my Engine Lathe to an 8-Station Turret Lathe! widgitmaster General Metal Working Machines 93 10-31-2011 03:27 AM
Lathe Turret Design FritzX Mechanical Calculations/Engineering Design 19 06-15-2010 03:08 PM
Turret Index Only Once In Auto rajesh_1355 Fanuc 1 01-28-2007 05:48 PM
