Old 11-10-2007, 10:26 AM
cncuser1 is on a distinguished road
Auto tool changer Q from newbie
On Vertical milling machines, when the toolholder is released from the spindle: Does the toolholder get knocked out from the spindle by the gripper mechanism?
Or is it pulled out by the rest of the change mechism or is gravity relied upon because it is not a self locking taper?
Old 11-10-2007, 01:57 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
On the VMC's I've been working on there is no knockout mechanism.
The gripper releases it and the arm pulls it out.When the gripper opens the tool is pushed out a bit ,but not by a knockout pin.
Old 11-10-2007, 05:07 PM
Knockout
Originally Posted by Mitsui Seiki View Post
.......When the gripper opens the tool is pushed out a bit ,but not by a knockout pin.
This is what I meant, the toolholder is given a little nudge by the gripper mechanism to break contact with the spindle taper.
Old 11-10-2007, 07:04 PM
Exactly.If it does, everything's ok.
Old 11-16-2007, 05:25 PM
Follow-up question
I have another question.
When the toolholder is fully pulled into the spindle, is there any clearance between the toolholder flange and spindle face.
I would imagine there would be, because you'd want to have the full effect of the taper.
Auto tool zero wildcat Mach Mill 30 10-08-2010 11:03 AM
The Zbot from LMS(auto tool changer) RedDog22 Benchtop Machines 10 04-01-2010 09:15 PM
Auto Tool Zero Moondog Machines running Mach Software 13 12-22-2006 06:02 PM
5th axis and Auto Tool Changer coolman Commercial CNC Wood Routers 4 01-11-2005 11:48 AM
