Old 11-09-2007, 11:41 PM
FullyBuiltJosh is on a distinguished road
What Machine to Buy??
I don't know if this is the proper place to put this thread, but with everything in here I thought this would be a good place.
Im in the market for my first CNC machine. Right now I work on a standard Lathe, and Mill, but the hand porting of my cylinder heads, manifold, etc...is becoming very old, and with my company growing I know this will make it much easier to get the job done.
I know a little bit about the machines, but Ive always wondered with something like a Cylinder head or intake manifold how many axis's are necessary? I know that it would have to do a bit more than just x to y in a straight line, but does that mean I will need something as much as a 5 axis to get the job done.
All and all Im a small performance auto business looking to cut down on time for hand porting and also ensure that it comes out identical each time rather than having screw ups that are a given with hand porting.
If anyone could take the time to educate me a small bit and point me in the right direction on what machine would suit me I would greatly appreciate it.
Thanks so much for your time.
Old 11-10-2007, 02:02 PM
307startup is on a distinguished road
http://www.centroidcnc.com/buy_machine.htm
http://www.millportmachines.com/rhino5.htm
http://www.rottlermfg.com/machine_in...products_id=61
These are just a few examples of machines that are capable or marketed specifically for CNC porting. You can do the same thing with a Haas mill using a 5 axis rotary table and the proper software. You need to decide if you are only going to be using this for CNC porting, or if you'll have a desire or need to manufacture parts of your own design or producing for others, if you will have enough volume to justify purchasing the machine, etc.
Good Luck to you!
Old 11-10-2007, 03:28 PM
Jarwalcot's Avatar
Jarwalcot is on a distinguished road
Mr. Fully,
I have several shops here in Georgia doing heads... Some of these shops have 5-Axis mills some have 4-axis mills others have simple 3-axis + indexer setups... From what I've seen over the years, all of them still seem to have the same amount of time in the parts they're producing. Regardless of how you process the part there is still a need for hand blending... This blending process is what make the part yours and allows you to maintain the market share you enjoy now. With that said, here are my thoughts:
1. Produce Less and Charge More... Sell the value in the amount time it takes to produce a quality product.
2. 80% of you business comes from 20% of your customer base... If your going to add machinery see what other needs the 20% have and buy the best setup that allows you to support those needs as well as your own.
I hope this helps... Good luck and con'grats on your success. Keep it up!
Have a great weekend,
JR Walcott
Georgia Machine Tool Resources, LLC
Old 11-13-2007, 02:43 AM
Thanks so much for your help in this. I greatly appreciate it. I knew that I would still have time in hand blending, but I am a person who focuses mainly on perfection and I know that a machine that does the SAME type of machining every single time will product a 100% better product in the end. The work will be less because I will spend less time ripping my hair out wondering on if the end product is what I want it be.
Again thanks for taking the time out to help me on this.
Old 11-13-2007, 09:14 AM
Jarwalcot's Avatar
Too funny! You will still rip your hair out! That's why we're still in the business... We want to succeed!
No matter what you decide to do, make sure you keep in mind that there will be a huge learning curve in font of you. Don't get discouraged, its the nature of the beast. You will get through it!
JR Walcott
Old 11-13-2007, 09:33 AM
ZipSnipe is on a distinguished road
Keep it simple. 3-axis cnc with a manual indexer(you can easily set up vertical positions) or spend extra get one cnc'ed. This will keep you within a decent budget and if ya check out Ebay and other auctions you could probably get ya a sweet deal on a VMC(Vert,Mach.Cent.) a lot these machines are up for bid due to a huge number of shops closing doors. Or for new,HAAS,Chevalair and Mazaak all look like good machines. RESEARCH before making such an investment. I,m starting small(Spectralight cnc) got it at a government auction $320. So my investment is pretty small and I can learn the ins and outs of cnc. Of course it helps that I work nights for a moldmaker with several cnc machines. Anyway good luck to ya.
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 09:37 PM
paper printer machine like cnc machine ??? patriciooholegu Mechanical Calculations/Engineering Design 3 08-07-2007 08:19 PM
Use Machine Shop vs. Buying Machine imp22b General Metalwork Discussion 15 06-06-2007 06:33 AM
G Code Variances from machine to machine? Miguel Gonzalez G-Code Programing 16 03-28-2007 03:31 AM
Mach 2 on old machine = great machine foamcutter Machines running Mach Software 6 12-16-2005 12:11 PM
