Old 11-08-2007, 08:59 AM
squale is on a distinguished road
What's the different between a CNC Swiss Lathe and a regular CNC lathe?
I'm just wondering what's the difference between these two? I am familar with a regular CNC lathe that has a 3,4, or 6 jaw chuck that you manually put the material into. For instance our machinist uses a Trak Lathe with an 8-tool square turret.
Old 11-08-2007, 11:25 PM
DSL PWR is on a distinguished road
A swiss lathe moves the stock instead of the tool. This works well for thin pieces, as the cutting happens close to the chuck.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 11-09-2007, 02:52 AM
erd39030 is on a distinguished road
The swiss type lathes I know use a collet to grab the stock (like the chuck) and a guide bushing to hold the material close to the tool, thus avoiding deflection while cutting.
Old 11-09-2007, 09:54 AM
Tcooper571 is on a distinguished road
Check out www.cma-citizen.com, they offer both Swiss and conventional lathes.
Converting my Engine Lathe to an 8-Station Turret Lathe! widgitmaster General Metal Working Machines 93 10-31-2011 03:27 AM
Swiss Lathe, Tool Change Position John3 General Metalwork Discussion 6 08-06-2007 06:46 PM
swiss lathe tooling help reddog37 General Metal Working Machines 36 06-28-2007 05:20 PM
Swiss Lathe Tooling? solgood General Metal Working Machines 8 12-15-2006 07:26 PM
Anyone have a mini cnc lathe or medium sized cnc lathe nymachinist Mini Lathe 6 01-23-2006 08:36 PM
