Old 11-06-2007, 05:12 PM
cskedk is on a distinguished road
Strippit #fc-750 Cnc Punch Press
I'm looking for an entry level turret punch press and have a lead on a STRIPPIT #FC-750 CNC PUNCH PRESS. Does anyone have any feedback on this machine such as known quirks and is there any support for parts and tooling? I've heard that the programming leaves something to be desired.
THanks in advance
Old 10-24-2009, 02:34 PM
zakir.panoli is on a distinguished road
i have the same machine
i just got the strippet fc 750 . but i dont have a software for it. would you mind guiding me along? which one should i get? or how?
Old 11-26-2009, 11:36 PM
PhoenixMetal is on a distinguished road
I don't have a strippit, but have other brand turrets (Amada and Wiedemann).
You need two pieces of software:
1) Software to draw your parts and specify which tools hit where on the part, and to repeat that shape to fill up a whole sheet of material, and to convert that drawing/hit info into gcode which your machine can understand.
2) Software to transfer the gcode to the machine control (called DNC software).
For the drawing/gcode generation software, there are several expensive packages (starting around $5,000 or so), and one program which costs only a few hundred. It is called gpuncher - http://www.metalpuncher.com/ . That's what I use, and I reccommend it. Not only is it affordable, but well it works fine (yes it does have some quirks) and there is no way I could justify paying over ten times its cost for another brand of software that does the same thing.
For the DNC software, there are lots of packages out there as this same software is also used for cnc milling machines which are much more plentiful than turret punch presses. Make sure that the software package has the ability to repeatedly send the same file over and over since this is likely how you will be running the machine (running lots of sheets of the same file), wheras I have found most of the DNC software to be more oriented towards sending a file once (and then you'd have to re-select the file on the computer to send it again). I can't reccommend a piece of software in this department as ours is super old and specific to the piece of hardware that it is feeding data to.
Old 11-27-2009, 10:26 PM
ah thanks man, your reply really helped. i really cant believe their price!
im gonna go with this and hope for the best.
Old 11-30-2009, 08:47 PM
Glad I could help. The owner/programmer of gpuncher has been really helpful to me so I'm glad to send people his way. When I first got the software, he spent a good amount of time on the phone with me to answer my questions and make sure I was up and running.
Old 02-22-2010, 12:40 PM
maglat is on a distinguished road
Hello!
Is everything ok with it? I can't contact with them.
Old 02-22-2010, 01:02 PM
Originally Posted by maglat View Post
Hello!
Hmm, don't know - I haven't needed to contact them in a while. Try reaching Joe at kzxsoft@embarqmail.com . That's the email I've used get in contact with them in the past.
Old 02-22-2010, 01:24 PM
SMTP error from remote mail server after RCPT TO:<kzxsoft@embarqmail.com>:
host smtp.embarq.synacor.com [208.47.184.2]: 550 5.1.1 Recipient
kzxsoft@embarqmail.com does not exist here
Old 02-24-2010, 07:31 AM
Hi there!
I have Strippit FC 1000R cnc punch press and AppleMac for it. What software or something i need to work with it?
Arturs
Old 03-31-2010, 06:49 AM
Dave2962 is on a distinguished road
kzx software
I have been trying to contact kzx for a few weeks now. I have used their software for several years to program an Amada. I am trying to get a post for a Strippit 1000R but I can't get a response from them. I hope they have not gone out of business.
Dave
CNC punch press software Uglybob General CAM Discussion 23 08-20-2011 10:47 AM
CNC benchtop punch-press 307startup CNCzone Club House 9 12-06-2010 08:07 AM
NorthStar Press Brake For 20 Ton Shop Press anyone ever use one? dsmdude Bending, Forging,Extrusion... 6 04-13-2007 04:01 PM
Strippit Super 750 SG cncdiag Fanuc 4 02-03-2007 02:42 PM
Help with HECC80/3 controller (Strippit) strider_28314 Machine Problems, Solutions , Wireless DNC, serial port 2 01-03-2007 03:39 AM
