Old 11-06-2007, 10:17 AM
Aero98's Avatar
Aero98 is on a distinguished road
Calculating Reamer Torque
Does anyone know of a good formula for calculating torque requirements for a reamer.
I have a 16 flute 2.5625 straight flute reamer going into a 2.555 hole and the material is 1018. It's a weird assembly and we are building a machine to ream these holes that start 36" down a tube.
thanks,
Matt Henley
Old 11-06-2007, 11:09 AM
ataxy's Avatar
ataxy is on a distinguished road
torque or do you mean rpm? if its rpm then use around half the speed you would use for drilling the same hole
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 11-06-2007, 12:01 PM
Aero98's Avatar
no, I dont know how much torque a motor will need.
Old 11-06-2007, 01:34 PM
neilw20's Avatar
neilw20 is on a distinguished road
Cool Try a sample.
Can you ream a similar part on an existing machine.
If so, measure the supply current before you start cutting, do some cuttng and measure the current.
Subtract idle current from tha largest reading you got.
Multiply that by supply votage, and divide by 746.
That's roughly the horsepower you used, plus whatever losses crept in.
You need at least that much.
If the supply is single phase it is easy. If multiphase, then it gets more complicated than above.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
need help calculating motor torque for gantry eloid DIY-CNC Router Table Machines 2 10-21-2007 07:18 AM
Calculating forces and torque in drilling VNR Mechanical Calculations/Engineering Design 2 05-13-2006 09:30 PM
Reamer Question? cncshawn Machine Problems, Solutions , Wireless DNC, serial port 3 12-07-2004 10:37 AM
Adjustable Reamer Question Joe_CNC General Metalwork Discussion 6 11-07-2004 08:27 AM
Calculating Motor Torque creative_mind General Electronics Discussion 2 01-08-2004 10:52 AM
