Old 06-08-2004, 10:37 AM
lt paul's Avatar
lt paul is on a distinguished road
R8 taper
After examining the specifications of the r8 taper i am curious about how the taper is formed. specificly the keyway, is it just an insert atached from the outside? or is the whole taper EDMed or is the hole pre cu on a lathe and finished with an EDM? just wondering since tool construction is one of my intrests.
Old 06-10-2004, 09:24 AM
Gold Member
JFettig is on a distinguished road
it would be turned on a lathe, then the keyway typically looks like it was cut on a horisontal mill with a slotting saw type thing, same with the other slots.
Jon
CNC Mini Lathe Plans and Rotary Table kits:
http://jfettigmachines.com
Old 06-10-2004, 10:31 AM
3t3d is on a distinguished road
The "key" is just a ground down dog point set screw. It is easy to remove.
Many shops remove the "key". It reduces damage to tooling and collets.
The taper itself will transmit any erasonable amount of torque.
Hope that helps.
Pete
Taper Roller Bearings VS Angular Contact mxtras Linear and Rotary Motion 26 10-12-2007 11:32 AM
BT30 taper spindle for mold making grantmi1 Hard and High Speed Machining 5 02-28-2006 02:41 AM
CNC Router Taper Machine hadjcues DIY-CNC Router Table Machines 8 03-23-2005 05:02 PM
30 taper tooling mtechserv General Metal Working Machines 3 03-15-2005 08:41 AM
Spindle taper differences 71CJ5 General Metalwork Discussion 3 11-17-2004 12:00 PM
