Old 11-03-2007, 07:35 AM
teamtexas's Avatar
teamtexas is on a distinguished road
What bit to use to drill C channel?
I have 18 pieces of 3" standard steel "c" channel that I need to drill a 7/8" hole through. I have been using a HSS bit and a special jig on my mill to hold the piece up. The biggest problem I have is when it goes through the first side the angle of the channel on the id makes the bit deflect and elongates the hole. I'm running the bit at the slowes speed I have 150 rpm. I have to lay out and drill each side seprately because of the ID angle. I keep thinking there must be some sort of carbide bit drill that I could run at a faster rpm that might give me a cleaner finshed product.
Dan
Old 11-03-2007, 07:51 AM
Gold Member
Ken_Shea is on a distinguished road
Dan,
hmmmm, that is a problem, what about plunge cuts using a .875 end mill?
Ken
Old 11-03-2007, 08:32 AM
teamtexas's Avatar
Ken, I could give that a try. What style end mill would work best? Would I need a pilot hole or would the end mill be able to drill as well?
Dan
Old 11-03-2007, 08:42 AM
Drill a pilot hole as large as possible so that the hole elongation from the pilot drill is a bit less than the diameter of the milling cutter. End mills do not like to plunge straight in and tend to wander about because they do not have a point to center them.
I would use a HSS end mill and go quite slow because the mill scale on the channel is abrasive.
Old 11-03-2007, 08:47 AM
Gold Member
Dan,
I guess be glad you only have 18
4 flute center cutting so no pre-drill would be necessary.
Use cutting oil, needless to say.
Step up the rpm a bit, maybe double that of your drill.
I have seen these having a 3 1/2 LOC which would be ideal in your case.
I am looking at one now on eBay for you for $30, a good buy, not sure of the LOC but I have sent an email inquiring and it does look long enough.
http://cgi.ebay.com/ws/eBayISAPI.dll...MakeTrack=true
Ken
Old 11-03-2007, 08:54 AM
Gold Member
Not to disagree with Geof as he has forgotten more that I will ever know !
However, manual end mill plunging in steel is not that big a deal and goes quite smooth. As he has said make the cuts small, kinda like peck drilling.
I do not think you will need to take the extra time for pre-drill, just try with out and then with and see how it goes.
Ken
Old 11-03-2007, 11:58 AM
teamtexas's Avatar
Thanks for your suggestions guys, I'll give it a try.
Dan
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
Lube channel flush?? zoeper General Metal Working Machines 9 05-23-2006 11:54 AM
80/20 versus u-channel SteveT44 DIY-CNC Router Table Machines 4 11-19-2005 04:39 PM
IRC channel for EMC Dan Falck LinuxCNC (formerly EMC2) 0 12-18-2004 11:03 AM
Two steppers from one channel? m1911bldr General Electronics Discussion 1 03-29-2004 08:30 PM
