Old 11-03-2007, 12:46 AM
Khalid's Avatar
Khalid is on a distinguished road
Smile CNC TIG WELDING MACHINE (Router Type)
My next Project is CNC TIG (Tungstun Inert Gas) welding machine.... If somebody tried on it... please share the knowledge..
Best Regards
Old 11-06-2007, 08:39 AM
KTP KTP is offline
Gold Member
KTP is on a distinguished road
I think it would be awesome. I have a ThermalArc Prowave 185 amp inverter model that I was thinking of using for a similar machine. I have such a hard time keeping the tungsten tip out of the weld pool and yet keeping it close enough to the work, not to mention feeding in the sacrificial metal rod. Actually, how would you handle the feeding in of the extra metal? Some sort of servo gearmotor pinched roller device?
My inverter probably generates a huge amount of EMI when welding, so that would be something you would need to protect your cnc system from (I could see getting lots of noise on encoder and step/dir lines if they were not correctly shielded).
Old 11-06-2007, 09:30 PM
mog5858 is on a distinguished road
i am working on one right now to be use as a pipe cutter/ welder. i am plaing to just use a mig where there is no high ferkenz need to start the ark the tig. the one i have look at eather just use the paernt meat or they just a wire feed box from a mig.
Old 11-06-2007, 11:25 PM
gotis is an unknown quantity at this point
You could try this one when you are welding manually.
http://store.cyberweld.com/tigpen.html
Old 07-11-2009, 11:11 AM
D_ego is on a distinguished road
I have tried..
Best Regards
Hi Khalid, i made a cnc Tig welding table, two years ago, but i could not finish, becose in the firsts test, i burn my drive box, (i bought the a Xylotex kit)
I weld with a high frecuency ingnition (cebora welding), my first misstake was the i did´t connect a earth pole to the table, so in the first test one of the motors die, so i put the earth pole and made a new test, this time it`s work well but a have some problems, so a have to left the project. ok i hope that this will be usefull for you, bye.
CNC Welding Machine? Kraig1 CNC Plasma and Waterjet Machines 4 05-15-2012 08:22 PM
Tig welding around your machine TT350 Tormach PCNC 11 09-24-2007 08:40 AM
Please Recommend a Home welding machine ThomasAlva Welding, Brazing, Soldering, Sealing 8 08-23-2007 01:34 AM
router for cnc welding anil DIY-CNC Router Table Machines 3 06-18-2007 02:12 PM
Welding Larger CNC Router tables Sub thread jsage Open Source CNC Machine Designs 1 02-03-2007 03:19 PM
