Old 06-06-2004, 10:14 AM
kong is on a distinguished road
What is this collet size?
Hiya guys, I have just got home with this old mill:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN%3AIT&rd=1
And it has come with a set of collets, which are known as "er type". I have measured them, but comparing the measurements to a chart I found on the net, they are too big for er25 and too small for er20. So is there an old imperial type of er collet out there? Thanks, Jason.
edit - oops, I forgot the major diameter of the collet - it is 28.5mm
Old 06-06-2004, 12:17 PM
HuFlungDung's Avatar
Moderator
Kong,
It could be an obsolete collet, just from looking at the pictures on the listing. All the current technology ER styles, now use a special nut that engages a groove cut into the circumference of the collet near the apex of the corners. This facilitates pulling the collet out of the taper after it has been locked in.
So because the groove is cut into the collet at the apex, this might be why the dimensions don't match. I would still guess that it might be an ER25 according to this chart, but if it isn't well, then it isn't
http://www.rego-fix.ch/english/suppo...einfo/13-1.htm
Old 06-06-2004, 01:07 PM
Thanks Hu, I will see what ebay has to offer and buy an ER25 collet. Alternatively, I may be able to get a new holder.
Calculating draw bar force on R8 collet h3ndrix General Metal Working Machines 8 07-27-2005 04:51 PM
for engraving pcb which is a good thread size for the lead screw? NickLatech DIY-CNC Router Table Machines 11 01-17-2005 08:37 PM
Your opinion on adapting my router collet MrBean DIY-CNC Router Table Machines 5 12-03-2004 11:02 AM
Ballscrew size -vs- project size Alan T. CNC Machining Centers 4 10-18-2004 08:53 PM
Sealing a collet? HuFlungDung General Metal Working Machines 6 04-13-2003 05:36 PM
