Old 10-22-2007, 05:25 PM
mbam is on a distinguished road
Old school iron - Cincinnati Hydrashift
Not sure if this is the right forum, but what the heck, it's a machine tool and it does have digital read outs . I have an older Cinci lathe that we use pretty much daily. We just noticed that it is not making round parts.
After scratching my head for a while I'm thinking bearings in the headstock. If I cut a piece of barstock and put an indicator on it I am seeing .002-.003 runout, and the high spot is not in the same spot on every revolution, it moves.
Anyone ever seen this?
Thanks!!
Marc
Old 10-27-2007, 09:16 AM
Freddy4 is on a distinguished road
Marc,
I would check the end float on the spindle with a dial indicator. There should be .0005 to .0008 end float , max .001 on the spindle. If it is outside of these findings adjust the endplay by tightening the locknut that adjusts the cup/cone bearing inside. There should be a slight drag if the clearance is correct when you turn the chuck by hand. It will benefit from a run in period to see if excess heat is generated. I have found that it will run warm initially then come into its own. If it continues to run to hot then back of the tighening adjustment slightly and repeat the process. We had a machine that I serviced because of the same problem and in addition we found that face cuts and surface finish surfered as well.
Freddy4
Old 10-31-2007, 06:39 AM
Thanks, turns out it needed bearings. Was lucky to find the front one on Ebay as they are hard to find for this model.
Runout is now in the .0001 range.
Marc
Old School Calibration kenbarra Calibration & Measurement 4 04-30-2007 07:16 AM
New cnc school warnercnc CNCzone Club House 1 02-19-2007 10:25 PM
School in Socal? Do.kevin Employment Opportunity 0 01-18-2007 01:12 PM
School Project Strider2006 Mastercam 1 12-09-2006 05:20 PM
School CNC Mill dpbarry General CNC (Mill and Lathe) Control Software (NC) 3 03-06-2006 05:41 PM
