Old 10-18-2007, 01:41 PM
Twistr is on a distinguished road
Smoke in my shop
I could use some advice regarding getting rid of smoke that is produced while cutting stainless steel. Does anyone have any experience with oil and mist collectors? I have been looking at the type that mounts to the machine and runs a motor to create "impaction" of the mist particles, ultimately turned into a fluid and returned to the machine.
If you have this type mist collector, I would be interested in your feedback.
If you don't have this type collector, I wonder, What ARE you using? and how well does it work? What kind of maintenance is required?
Any help would be appreciated.
Old 10-18-2007, 06:21 PM
On the machines we have a mist collector system that draws everything through big filter bags; I am not sure what pore size is but it is small. The mist is retained on the bags and most of the water evaporates off and the oily coolant residue drains down and drips off the bottom and runs out through a drain hole into a tank.
On our welding room we have a similar system that has multiple pre-filters followed by the bags and this takes out all the welding fumes.
I can look at the nameplates and post the manufacturer's name next week when I get back to the office; remind me if I forget.
Old 10-19-2007, 06:16 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
The local bearing and aerospace manufacturers here think the Torrit Dryflo's are the best. I have often wondered why the don't use central or multi-machine systems, but for some reason they don't (I have never asked).
They install a Torrit for every machine.
www.integratedmechanical.ca
Old 10-19-2007, 07:46 AM
Originally Posted by DareBee View Post
....They install a Torrit for every machine.
I considered this but was worried the noise level would be higher. Have you been in these places?
Old 10-19-2007, 12:19 PM
JROM is on a distinguished road
Google "smog hog"
They make all kinds of air moving and filtering equipment.
They have portable units that you can roll around the shop to where ever you are making the smoke.
Be carefull what you wish for, you might get it.
Old 10-19-2007, 12:58 PM
DareBee's Avatar
Geof the Torrit's are very quiet and are designed specifically for mist. Also you can't hear them when there are 200 CNC's running.
The smog hogs, Plymovent, etc are made for fume and particle extraction. They tend to be quite noisy because they need to move a lot of air, I would not use this type of unit for mist.
The Torrit units that I am most familier with are only about a 20" cube as well.
Smoke? Through the Spindle? donl517 Fadal 32 06-10-2010 08:31 AM
did i smoke ya ! superrotary I.C. Engines 1 09-28-2007 11:26 PM
Motors Up in SMOKE 69owb Servo Motors and Drives 3 01-27-2007 09:48 AM
Why did the smoke escape? obscurity Stepper Motors and Drives 5 05-28-2006 11:34 PM
no smoke but............... turmite General Electronics Discussion 14 12-06-2003 05:27 PM
