Old 10-11-2007, 04:39 PM
dneisler is on a distinguished road
How to get this finish
How do you go about getting this finish on the face of this putter?
***For full up to date details visit my blog @ www.donald-neisler.com
Donald Neisler
Old 10-11-2007, 06:13 PM
MrWild is on a distinguished road
A fly cutter. One cutting tool, maybe two with a very fast travers. Pretty simple really. I've seen it plenty of times with an improperly applied rapid.....
Old 10-11-2007, 06:42 PM
Make yourself a 'flycutter' using a threading insert mounted to cut on the end of the toolshank not on the side.
Old 10-11-2007, 07:09 PM
One of Many is on a distinguished road
It also appears that the mills head was slightly out of tram by the runout fading at the edges verses deeper toward the middle. That may also indicate that the pattern was put in there with two operations, as in flipping the part around to get the crosshatch or that the face is not quite as flat as it looks.
I wouldn't expect a putter to have an arched face, but I'd be the first to admit I know nothing about pasture pool tools.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
I need to finish this machine. runinbymdnt Commercial CNC Wood Routers 4 07-20-2008 04:19 PM
Surface finish skmetal7 Mini Lathe 7 09-10-2007 12:56 PM
Finish Cut How too ??? Biggermens BobCad-Cam 6 04-30-2007 07:59 PM
surface finish fadalman BobCad-Cam 2 03-03-2007 01:30 AM
Bad finish fadalman Fadal 5 12-09-2006 01:00 PM
