Results 1 to 6 of 6
Thread: CNC Vertical Turning Lathe
    Registered Harshwardhan's Avatar
    Aug 2007
    India
    Question CNC Vertical Turning Lathe
    I need to design and build a CNC vertical turning lathe (not a retrofit).
    Can anyone here help me professionally with the design calculations? You can also reply directly to my email address with experience and terms.
    Harshwardhan
    harsh@neubauplan.com
    May 2007
    What is there to calculate? Just about anything can be calculated, but what do you need calculated?
    Aug 2007
    India
    Good point!
    May 2007
    1)First, you need to read up and figure out how much accuracy and precision you are looking for.
    2) Then, you would learn the most and in the shortest amount of time by simply reading up on various builds (including routers and retrofits), and seeing the steps they went through to gain a certain degree of accuracy.
    3)Lastly, and this kindof blends in with the second step, it will be very useful for you to have at least a basic understanding of common materials, and their properties before and after being worked. Like how Cold Rolled steel is more dimensionally accurate than Hot Rolled steel. And how metals will always warp to some degree after welding. And about cost-effective ways to increase stability / reduce vibration (like concrete filling).
    The simple definition of "Engineering" can be stated as "The best possible outcome with the least possible effort." That is, get as close to the goal (typically "perfection") as possible, but with realistically limited resources.
    With that said:
    1) How much money do you want to spend on the whole product (resource)?
    2) How much time and effort do you want to put into it (resource)?
    3) What kind of specs are you looking for (size, accuracy, capacity, etc)?
    1 and 2 are inversely proprtional... for the most part, cost doesn't go down without effort going up. Likewise, time and effort don't go down without cost going up. Both of those will always "equal" the end result. Given a million years, you could probably build a mill that was accurate to .0001", with scraps lying around town. Conversely, if given a million dollars, you could probably build the same mill, but spend about 30 seconds of your time doing it (I.E. call up somebody and tell them what you want). Of course, these are unrealistic scenarios, so you have to find your balance in between.
    Ive been designing my mill for about a month. My budget was $1500 max. My total looks like it will be around 1250-1400. I was eventually able to work in all linear bearings, as well as a much better head design, and finally the same work area into a much smaller overall space.
    ged
    ged is offline
    Jun 2006
    canada
    vbm's(verticle boring mills)
    take a look at Olympia verticle lathes.that might give you some ideas
    Mar 2006
    How big? A DIY miniature or a commercial size machine? How about size in mm or inch, accuracy requirements, weight of workpieces plus workholding devices? Sounds like an interesting project. Good Luck
    DZASTR
    1. lathe turning
      By klugster in forum General Metalwork Discussion
      Last Post: 11-01-2012, 12:25 AM
    2. which lathe for ballscrew turning
      By margni74 in forum Benchtop Machines
      Last Post: 08-30-2007, 09:54 AM
    3. Ghost keeps turning on lathe output.
      By Jim Estes in forum BobCad-Cam
      Last Post: 06-29-2007, 10:38 AM
    4. $760 Northern tool selling Vertical mill + Lathe combo
      By OckamsRazor in forum General Metal Working Machines
      Last Post: 03-19-2006, 08:10 PM
    5. non-circular lathe turning Help!
      By oldguy in forum General Metal Working Machines
      Last Post: 04-06-2004, 12:55 PM
