  #13   Ban this user!
Old 05-04-2003, 06:56 PM
barry is on a distinguished road
You might want to try screw machine length drills. They are shorter in length and have I believe a 135 degree point. Also check your rpm speed you don't say what size bit you are using but with cutting aluminum say using a 1/8 bit you would want to be somewhere around 250 SFM which would put you 7639 RPM. Good Luck
barry
  #14   Ban this user!
Old 05-04-2003, 09:06 PM
boxwood is on a distinguished road
Hi
1 First check to see the material is running true place an indicator on stationary part of lathe ie ways,cross slide and put the neddle on your work piece and turn the chuck by hand this will let you know if the part is way off or not
2 also you can check your tailstock alignment by placing magnetic base indicator on face of chuck and the needle on the tailstock quill takes a little positioning and rotate the chuck slowly by hand there sould be adjustment screws on the base if it is off
3 those are some cheap drills I have had some that where actually sharpened backwards maybe try anothe drill and see
4 last but not least make sure the chuck is turning the right way
no offense I have made this mistake so i mentioned it.
Hope this helps good luck
Old 05-10-2003, 11:11 AM
HuFlungDung's Avatar
Moderator
James, you didn't say how far you are trying to drill before the bit starts to wander off center. It is practically "normal" for some wander to occur, let's say if you drill a hole that is deeper than 4 to 6 times the drill diameter. Hence the need to drill, then bore the hole to straighten it up.
You said you had faced the end before drilling, which is good, as I would have said that a drill bit approach that is not perpendicular to the surface will always wander on entry.
However, practically all other machine adjustments have little to do with wander during drilling, that is, if the start of the hole is good, but the exit side is out of center.
If your tailstock is misaligned, you will notice the drill bit jumps over immediately when touching the spot hole, because the drill must gravitate to the rotating axis of the part, if it is sharpened equally on both lips.
Do not move the part between the spotting operation and the drilling operation if you can help it. 3 jaw lathe chucks are seldom accurate enough to put the spotting hole back on center if you move the part. On a long part, use a steady rest to support the part for both the spotting and drilling operation, so you don't have to move the part.
When drilling holes that are too small to bore easily, what I sometimes do is drill a smaller hole to start, then use an endmill as a drill to true up the hole for as far as it will reach, then switch back to a drill bit the same size as the endmill, and attempt to bore out the eccentricity of the deeper part of the hole. This is like using the front of the hole as a guide bushing to help guide the drill.
Don't feed your drills too lightly, nor too heavily. Too light of a feed will make them squeal, as there is too much rubbing going on. Keep the cutting lips under the chip.
  #16   Ban this user!
Old 05-10-2003, 12:59 PM
Durkee is on a distinguished road
HuFlungDung pretty much has it nailed with that last post I think. A little more info from you James may make it easier for us to help out.
What size drill are you using and at what RPM's are you turning your workpiece? Sometimes a small CNC spot drill with a flatter point on it than the point on your drill will work better than a drill/countersink.
In non-ferrous mat'l, a lot of guys make the mistake of not using enough feed on the tooling which will cause chatter. Feed is more important than speed, and that could be important, as most lathes will not turn the high RPM's required for small hole drilling or turning.
Where Your Quality Counts!
www.toolgrinder.com
durkee@toolgrinder.com
Stop Bits, Parity gar Computers and Networking 4 06-04-2005 02:10 PM
What type bits for routing PCBs? cp8071 DIY-CNC Router Table Machines 4 02-22-2005 10:08 AM
Drilling a perpendicular hole in drill rod material ngr1 General Metalwork Discussion 12 12-04-2004 09:16 AM
Newbie question on drill bits ezland00 DIY-CNC Router Table Machines 4 02-27-2004 02:53 PM
What type of drill bits for lathe? James04 Machine Problems, Solutions , Wireless DNC, serial port 9 05-19-2003 01:37 PM
