Old 10-01-2007, 04:11 AM
rajanish is on a distinguished road
venturi suction system
hi
i am trying to design a venturi vacuum suction system for chip extraction for diamond turning operation. can anyone help in finding the formulae for suction power required, compressor power requirements etc?
regards,
rajanish
Old 10-01-2007, 10:37 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
Hey! I thought I was the only Diamond Machinist here hehe!
I use one of these venturi extraction systems- when machining aluminium it clears the swarf in a big long thin strip- like tinsel.
I use a 1/2" diameter nozzle, the air pressure is about 60psi and the air hose is about 0.1" diameter. It works quite well untill it clogs, but I find that attaching a vacuum cleaner near to the output of the venturi system helps (obviously don't touch the venturi system with the vacuum cleaner- you know what vibration does to optical surfaces hehe). Also, having the spray mist coming from underneath the tool tip helps too.
Here's a piccy of it, not attached to the air line though.
I love deadlines- I like the whooshing sound they make as they fly by.
Old 10-01-2007, 07:24 PM
Hi Iman,
Thank you for your information. Would you please tell me how close you will keep that venturi to the machining zone since this also plays a role in sucking? i will be doing facing operation and my chips are going to be very fine like powder since i am machining brittle material not aluminum. and i am doing dry machining for my work piece
and it would be great for me if you know more about venturi design since i am planning myself to design my own rather than buying
thanks again
rajanish
Old 10-02-2007, 04:55 AM
ImanCarrot's Avatar
Brittle material? I'm guessing Germanium? make sure you use the right tool- got to have a -25 degree top rake for Germanium, obviously if your facing you want a large radius tool to minimise tool wear.
To be honest I don't use the venturi system at the moment since I'm machining plastic I don't use it on Germanium either- I only use it on aluminium to get the swarf out of the way otherwise it all clogs up and gives a poor finish.
I've attached a quick sketch of the basics of the system for you in ACAD format
Oh, I generaly have the venturi pipe as close to the workpiece as I possibly can.
You mention not using any coolant... that is very unusual- what kind of finsih do you get please?
Old 10-02-2007, 05:46 AM
its a optical material called KDP and applying diamond turning on this material. it is a not like other brittle materials like Ge, Si etc which are hard but is soft and brittle.
Having problems with chips on the surface and has a problem of 'Fogging' when a suitable coolant is used, that is why i use dry machining...
the surface finish i get is around 2 to 3nm....
trying to extract the chips during operation to eliminate the surface damage...
Old 10-02-2007, 05:53 AM
by the way what is the that ashperic formula in the diagram...i couldnot understand
Old 10-02-2007, 09:37 AM
ImanCarrot's Avatar
Sorry, my fault, the aspheric formula is used for when I'm designing lenses- it's nothing to do with the Venturi pipe sketch. I should have erased it.
I've never machined KDP, but I hear it's a non- linear crystal which is soluable in water- I suppose this could lead to problems with atmosperic moisture (fogging)? I also hear that the Top Rake needed is fairly steep at minus 40 odd degrees! I immagine this would introduce a conical error on the surface form?
Old 10-02-2007, 07:19 PM
rightnow i am using only 0 rake tool maintaining undeformed chip thickness less than cutting edge radius which gives negative rake effect.....
it has been shown this condition achieves optical surfaces(ductile mode cutting) on brittle materials
Old 10-03-2007, 02:16 AM
ImanCarrot's Avatar
Very interesting indeed. I've got a Germanium project coming up and they're teling me to use a minus 25 top rake tool.
Obviously I'd like to use a zero rake tool so that setting the tool height is easier.
Old 10-03-2007, 03:06 AM
Hi Iman, are you working in diamond machining industry or a researcher? i am doing my research work on ductile mode cutting of brittle materials......its good to see sharing knowledge on this subject..
Do you machine Silicon also?
  #11   Ban this user!
Old 10-03-2007, 05:47 AM
ImanCarrot's Avatar
Manufacturing- I've been doing Diamond Machining for over 10 years
We're manufacturing hybrid aspheric lenses at the moment in high index plastic for night vision applications.
I have machined Silicon before at another company. However, the tool would only last a few components then we got tool wear and the typical "grey" surface associated with this.
Yep, it is good to share, I think I've only ever seen one other Diamond Machininst on these boards!
I would be interrested to know what depth of cuts and Feeeds/ Speeds you are using- I can't immagine they'd be too different from myself.
  #12   Ban this user!
Old 10-04-2007, 04:07 AM
we use depths of cut 0.1microns to 3 microns and feed rate around 2-5 microns......we do research on ductile mode cutting of brittle materials....theoretical and experimental.....perhaps you can check this site http://serve.me.nus.edu.sg/nanomachining/index.htm for more info..
Made my own Venturi... Zippi Work Fixtures and Hold-Down Solutions 22 08-28-2011 04:36 PM
no suction? djtrickdog Vacuum forming, Thermoforming Etc 5 06-21-2007 07:00 PM
new 201 system rickwinters Gecko Drives 6 12-20-2004 10:10 AM
Venturi Vacuum Systems Moondog DIY-CNC Router Table Machines 6 09-24-2004 08:17 AM
CNC machine suction table margni74 General Metal Working Machines 2 12-31-2003 01:39 PM
