Old 09-25-2007, 09:37 AM
petriej is on a distinguished road
What to do about coolant?
We have a CNC mill at our shop that uses flood coolant. Typically water based - cool mist. But we recently acquired a large CNC lathe. Compared to what I am used to running, this thing is a beast, and requires fifty gallons of coolant. What is the best way to go? It is highly recommended by the manufacturer that we use an oil based coolant in this machine.
50 gallons oil based cooland ~ $750 = :-( .
What are your recommendations? I've used val cool and a few other types of coolants, but which is the best suited? I am turning mostly Al, not much if any ferrous metals.
Thanks,
J
Star SR20RII/Fanuc 18i, DMG CTX310V4/Fanuc 32i, DMG CTX310ECO/Siemens 8400, Mori NV5000/MAPS, Bridgeport 760/Fanuc 18i, Kiamaster 4NEII60/Fanuc 3t;Partmaker, Gibbscam
Old 09-25-2007, 09:58 AM
There are several to choose from for aluminum all water mixed. Blaser, Hansterfer, ? do a search here for coolant, scan through the Haas forum it has been discussed there. Straight oil coolant is not needed no matter what the machine manufacturer says; water mixed coolants both cool and lubricate which is what is needed. Straight oil coolants do not cool as well they just lubricate and they stink to high heaven.
Old 09-25-2007, 02:19 PM
star-turn is on a distinguished road
Only m/c's that require oil now seem to be sliding heads.
As Geof said - Nasty, smelly stuff that gives you zits the size of golf balls!
water based coolant is the way to go.
ST
Old 09-25-2007, 05:31 PM
Flavor?
What's your favorite flavor?
Old 09-25-2007, 10:34 PM
We currently use OEMETA
they have a good coolant for Aluminium - goes well in the m/c, no foaming, no has had any skin reactions, and has a pleasant odour!
ST
Old 09-28-2007, 01:59 PM
PoiToi is on a distinguished road
50 gallon reservoir?? that is a beast!
here I use blasocut universal, it works real well for 303 and aluminum, at about 10-12% for 303 stainless and you can run it at about 8% for aluminum, we get it in 5 gal. buckets and it lasts a few months.
ALso has a pleasent odor and no skin reactions or anything.. as long as you dont dump windex in the tank it wont foam, lol. ^_^
Old 09-29-2007, 07:11 PM
bremenrules is on a distinguished road
I use Hangsterfer's S-500 at ~8%. Machine came with a 5 gallon sample and I never saw any need to try anything else. I'm sure just about every forum on this site has a discussion about coolants, so I don't need to get into much detail. Soluable oil logically seems to be the best solution for an all-around coolant system. It cools better than straight oil, lubricates the cutting interface better than most synthetics and semi-synthetics, and isn't *too* messy. It's not perfectly clear or particularly clean - places it dries will be left with a thin layer of oil - but it can help protect your steel/iron-based tools from rust. Like anything else, it's more important that the coolant is used properly. Nothing in the world will work well if the flow is too weak or directed improperly.
Never attribute to malice that which can be adequately explained by stupidity.
Looking for a better coolant? shawn General Metalwork Discussion 9 06-29-2009 10:13 AM
Coolant...Which and why? ajl6549 General Metalwork Discussion 15 12-08-2008 08:02 AM
Coolant or No Coolant when turning.... Crashmaster General Metalwork Discussion 3 05-20-2007 01:20 AM
Best coolant machinist39 General Metalwork Discussion 15 05-13-2006 01:25 PM
COOLANT (what are you using?) carbidecraters General Metalwork Discussion 12 01-22-2006 12:31 AM
