Old 09-25-2007, 12:44 AM
owens15 is on a distinguished road
Tool Arm In Matsurra
Any idea how to get the arm in the home position, I caanot get it figured out. Thanks
Old 09-25-2007, 12:52 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
is it an ra ?
there should be a small cap up by the tool arm , take it off , there should be a spot to get a wrench once you remove the cap if you look up you should hopefully see a cover (outside the machine), push up on it and it should pop off ,now you should see a proximity switch to the right , wrench the arm around until the switch goes off
i've done it many times on the ra's
hope this helps
Old 09-25-2007, 12:55 AM
MC-510 VG Matsuura
Old 03-06-2011, 05:29 PM
victorcnc is on a distinguished road
I have this alarm: tool table error'' matsuura mc510v
Hello, pardon for the interference but you can help me to solve this alarm " tool table error " the arm changer I stop and it marks this alarm. That can be? It is a matsuura mc510v 1987'
Originally Posted by dertsap View Post
is it an ra ?
hope this helps
Fagor 800T Tool saving tool set-up jime Fagor Automation 8 02-02-2009 07:53 AM
G43.1 - Tool Axis Direction Tool Length Compensatioin EngTech Mazak, Mitsubishi, Mazatrol 8 12-06-2007 04:01 AM
Matsurra Mx-1-CPU Error JR1050 Machine Problems, Solutions , Wireless DNC, serial port 5 08-13-2007 05:31 PM
Does V20 program tool tip or tool center Pat BobCad-Cam 3 06-17-2005 05:46 PM
