Old 09-21-2007, 12:40 PM
sbalder is on a distinguished road
CMM Gantry Machine as a Router or Plasma table?
I could use advice from ANYONE who has ever worked with a gantry-style coordinate measurement machine. It seems that used machines like this, which can sometimes be found cheaply, would be good for making a smaller router or plasma table, but I have never looked at one up close.
What do you think? Obviously the granite bases are solid and straight. Are the ways/guides/screws strong and accurate enough for lighter-duty routing or plasma applications?
Old 09-21-2007, 12:41 PM
Here's a link to a picture of the style machine I am talking about:
http://www.xspectsolutions.com/used-...%207200&ID=354
Old 09-22-2007, 03:50 AM
Gold Member
Caprirs is on a distinguished road
The B & S CMM I have used has air bearings which would be completey unsuitable for any sort of side loading. The idea is air pressure allows the sliding components to float on a cushion of air. Too much load will squeeze the air out and cause direct contact between the sliding parts which would probably bind.
Old 09-22-2007, 12:44 PM
crazythunder is on a distinguished road
Another problem will be the unsupported side which has no support. I would rebuild it as a CMM. Also CMM scales do not handle dust or dirt very well. The vibration alone would probably be enough to tear everything up.
Robotic Plasma table instead of a gantry type? Hi-Vac CNC Plasma and Waterjet Machines 26 09-28-2009 12:58 AM
My first Router / Plasma Table Buildup... InventIt DIY-CNC Router Table Machines 88 01-04-2009 10:20 PM
Advice on Dual Plasma Router Table Mini-MillX2 CNC Plasma and Waterjet Machines 2 01-27-2007 05:04 AM
Conversion to programable independant heads for Gantry Twin head router table ohallock DIY-CNC Router Table Machines 0 04-18-2006 06:20 PM
Anyone using xylotex stepper kit for a cnc plasma or router table? muleworks Xylotex 2 03-10-2006 07:52 AM
