Old 09-21-2007, 03:17 AM
dex918 is on a distinguished road
My CNC design
I design this after learning from reading CNCZONE.
The specs is
X travel = 18 inches
Y travel = 16 inches
Z travel = 4.7 inches
The distance of the table top to the highest point of the gantry is about 12 inches.
Machine footprint is 35 inches (including motor at the back) x 26 inches and height is 13.5 inches.
I have not finalised this design as I need feedback or comments from you guys. This is my first attemp to build this machine. Any negative or positive comments is welcomed.
Old 09-21-2007, 06:25 AM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
According to the picture, the Z-axis leadscrew will be lifting both the spindle motor and the z-axis leadscrew motor! That's a lot of unnecessary work to move all that weight! Your screw and nut will wear out fast!
My 2 cents.
Widgit
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 09-21-2007, 08:16 AM
widgitmaster,
Thanks for the comments. I agree with you. However, redesigning the Z axis will definitely eliminate or reduce the unnecessary load. This will however reduce the X travel. Furthermore, the it will also reduce the clearance from the table top upward.
But, I will definitely consider your approach.
Old 09-21-2007, 09:10 PM
rustamd is on a distinguished road
if you flip around the Z assy you will not loose any travel and motor will not have to lift itself
Old 09-29-2007, 12:09 PM
after considering your suggestions, I finally decided to re-design the setup and this is what I have for now. Most likely it is final and will start to fabricates the needed parts.
Old 09-29-2007, 03:50 PM
Gold Member
Good design, but don't forget the four adjusters in the corners of the base, so you can level your machine for accuracy!
Widgit
Old 10-07-2007, 08:41 AM
just for updates.. The parts I receive for the machine... It's the parts for Y and Z assembly and the leadscrew mount bearing block.
[IMG][/IMG]
Old 10-08-2007, 10:18 PM
stevehez is on a distinguished road
Real nice keep us posted.
Old 10-11-2007, 05:19 AM
svenakela is on a distinguished road
My machines are running the same config as your first (as many others), if the motor has a problem lifting itself you have too small motors.
Both designs work though, it's just a matter of taste.
Regards,
Sven
Old 10-11-2007, 08:42 AM
Sven,
Thanks. I already re-design the Z assy as shown in the second attachment.
I am now waiting for other parts to arrive. I am using acme screw instead of ball screw due to the cost factor. As for the lead nut, I am still deciding between brass or delrin... which one should I use??
  #11   Ban this user!
Old 10-11-2007, 11:52 AM
JMcDonald is on a distinguished road
My concerns about using brass, a plastic, or even a soft aluminum (6063) is how accurate they will stay if you preload them or use another method of anti-backlash. It seems that while they would indeed run smoother because of their self-lubricating properties, they would constantly need adjustment due to the threads wearing. Is this true?
  #12   Ban this user!
Old 10-12-2007, 03:05 AM
This is my Leadnut. I plan to use delrin for it. The width is 50mm and the slit is 3mm wide. I am using 12mm acme, 2mm pitch. I use double row A/C bearing for the Acme mounting block (driven side), with 2 hex nut to lock it to the bearing and normal radial bearing for the floating side to prevent the Acme from whipping.
Now I have a problem where to put my machine since I am staying in a 850sqft flat.
Although I have dedicated room for my hobby works, it's only 5ft x 8ft.
Another design JIMMY CNC Wood Router Project Log 1 03-16-2007 03:52 AM
ATC Design Buzz9075 DIY-CNC Router Table Machines 5 03-04-2007 12:47 PM
another new design austin.mn DIY-CNC Router Table Machines 3 10-21-2006 01:04 PM
Design Cad/Cam dave6 General CAM Discussion 4 09-23-2006 08:00 PM
Could someone look at this design? candle DIY-CNC Router Table Machines 34 09-23-2006 04:10 PM
