Old 09-12-2007, 08:55 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Servo motor used as spindle motor?
Hey guys, just wondering if it would be a good idea to use a servo motor as the spindle motor. Seems that it would be easy to control using software, as far as on/off, speed control, ect.
The mills I currently have have 350W dc motors, no bigger than a nema 34 servo motor. They are rated at 6000rpm, which should be acheivable with a servo motor. I don't need a ton of power, but the contol from the software is an attractive option. They will be be geared down through pulleys to a proper R8 spindle.
Any thoughts would be appreciated.
Paul
Old 09-13-2007, 02:27 AM
messar is on a distinguished road
I'm doing what you are suggesting, and so far it's working OK. I'm using a 1hp emerson servo, and emerson drive in step and repeat mode on a Super X3. I changed the timing pulley on the motor side, and get around 4k rpm.
Matt
Old 09-13-2007, 02:36 AM
vroemm is on a distinguished road
Can you cut steel with it ?
Or only weaker materials ?
Old 09-13-2007, 06:49 AM
Lemo is on a distinguished road
That only depends on cutter and spindle. The motor only drives that lot. Consider that there are mills with one half of a horse power cutting steel.
Lemo
Old 09-13-2007, 07:04 AM
gridley51 is on a distinguished road
My Chiron mill uses the same type of servo motor for the spindle as the axis do.It`s a Siemens 1FT and a Siemens 610 axis drive.
Old 09-13-2007, 09:37 AM
Thanks for the input guys! I think I will give it a try. If worse comes to worse, I have a spare motor and drive...
Thanks,
Paul
Old 09-14-2007, 02:55 AM
Lemo
I was not worried about the strength of the motor.
(Dummy speaking. Plug your ears if necessary. :-) )
But the load on the spindle can change a lot and very fast.
Can the servo driver keep up with this ?
AC servo motor for the spindle david_geng Benchtop Machines 9 10-14-2011 04:37 PM
Servo for spindle motor?? turmite Servo Motors and Drives 14 11-30-2006 02:21 PM
Servo Motor Spindle BobWarfield General Metal Working Machines 12 09-29-2006 10:14 AM
Servo motor as spindle?? GalaticDan DIY-CNC Router Table Machines 3 07-11-2005 12:17 AM
Spindle power by servo motor Stevie General Metal Working Machines 4 04-18-2004 02:20 PM
