Old 09-10-2007, 10:01 PM
g-codeguy is on a distinguished road
Just applied for a job with a company that has
one of these machines coming in.
Anybody have some experience on one? I manual program for the most part, or use MasterCam. This machine will be conversational programming. Never done it, but it didn't look hard to do from what I was shown tonight.
Can you make money with it on small jobs?
Edit: You were right. That link sucks. Tried copying it a 2nd time with same results. It is a Mazak Integrex 300-IV ST.
Do a search for Mazak 9-axis lathe, and it should be the 1st link below the advertisement for Premier Equipment. Least it was for me both times I did the search.
Old 09-11-2007, 12:32 AM
ZipSnipe is on a distinguished road
That weblink SUCKS
Old 09-11-2007, 12:53 AM
Moderator
Halfnutz is on a distinguished road
Please give the model and make of the machine. The link you gave goes nowhere.
Halfnutz
Old 09-12-2007, 11:36 AM
crazythunder is on a distinguished road
No problem with Mastercam
If the machine is a single turret. The double turret machine is a bit of a bear but not to bad. You will want to make sure they have a good post for the machine. If they do not have a good post for the machine your life is going to be very hard and getting good programs will be a pain. Also you do not use the Conversational side when programing with Mastercam you use the .eia side or g-code side of the machine. You will want to make sure all of the parameters are set-up correctly.
Old 09-12-2007, 01:04 PM
Chuck Reamer's Avatar
Chuck Reamer is on a distinguished road
Not on small jobs, you need larger runs or extremely complex parts to make it worth its money.
Live free or die
Ask for a raise? Is your company do same to you CNCtoday Polls 32 11-18-2007 01:18 AM
force applied to table ? is there an easy way to calculate it ? jimtom Mechanical Calculations/Engineering Design 3 06-05-2007 09:36 PM
Old Company name on pendant Conquest1224 Machine Problems, Solutions , Wireless DNC, serial port 1 06-01-2007 07:31 PM
Have you ever applied for patent rights? widgitmaster CNCzone Club House 11 08-11-2006 12:04 PM
Cam- gear motor - force applied to follower? Chris D Mechanical Calculations/Engineering Design 3 05-05-2006 11:41 AM
