Old 09-10-2007, 02:21 PM
lilguy is on a distinguished road
Gear / Belt Lathes
I learned on small Southbends and worked with large Clausing/Colchesters. Have not had luck finding an acceptable small used lathe. Wether large or small, if I set it up right the cuts would be flawless. The consern I have is the reports I read comment that the small gearhead lathes will not provide fault free finish cuts. This is because gear vibration is transfered to the spindle and causes uneven surface finish. I have gotten quotes on the Griz G4003G, Jet GHB 13/40 and the Jet BDB 13/40. The Jet dealer said the above information is correct and that their belt drive will give better surface finishes.
It also has 12 speeds.What would be the best way to go with the low priced import lathes? Thanks
Basic Bevel Gear - Milling a valley for gear teeth ngr1 General CAM Discussion 10 04-05-2012 09:55 AM
MetalWorking Machines / Lathes / Mini Lathes widgitmaster Suggestions for the CNCzone.com site. 0 01-04-2007 05:48 PM
True Inch lathes? Gear change reverse or lever? anyone have the scoop on this? RMS Mini Lathe 9 07-31-2006 08:53 PM
Darn near FREE LATHES!!!! - 2 lathes, gotta go NOW! mxtras General Metal Working Machines 0 03-22-2006 12:43 PM
Lathes, what’s the difference between the different types of lathes out there? MrRage General Metal Working Machines 9 03-15-2006 02:07 AM
