Old 09-06-2007, 12:49 PM
lilguy is on a distinguished road
Used Leblond
Used machine, What problems do I Look for? Any and all help appreciated Thanks to all. Shawn
We are pleased to offer the following for your consideration:
(1) USED - 14" X 30" LEBLOND "REGAL" TOOL ROOM ENGINE LATHE*
Serial No. 2B-1755
SPECIFICATIONS:
Swing Over Bed and Carriage Wings 14"
Swing Over Cross Slide 8"
Center Distance Range 30"
Headstock Spindle Speeds - Number 12
- Range Low 45 - 132 RPM
- Range High 654 - 1800 RPM
Headstock Spindle Size of Center (Spindle Nose Bore) 11 Brown & Sharpe
Headstock Spindle Diameter of Hole - Straight 1-1/2"
Headstock Spindle Nose Taper Key Drive - Size L-00
Bed Width 12-3/16"
Carriage - Cross Slide Travel 8-1/2"
Feed Changes - Number 48
Thread Changes - Number 48
Range of Threads per Inch 4 - 224
Range of Feeds per Revolution .0032 - .106 IPR
Tailstock Spindle - Diameter 1-15/16"
- Travel 5"
Motor 3 HP
Approximate Floor Space Required 78" x 40"
Approximate Weight 1,500 Lbs.
EQUIPPED WITH:
Inch Threading
10" 4-Jaw Chuck
10" Face Plate
7-1/2" 6-Jaw, Buck Chuck
Square Turret Tool Post
Miscellanous Tool Holders & Centers
Chip Pan Base
Coolant System in Base
*Preliminary Specifications Subject to Verification.
PRICE: $3,250.00
Old 09-10-2007, 08:49 PM
keitholivier is on a distinguished road
Is it worth your while to spend $3200 ? You can get a decent new chinese lathe of the same size and equally heavy for that price. I bought my sheldon a few months ago, same size but much heavier (maybe they have the weight wrong) with a LOT of tooling and a DRO for $950.
Any lathe that old, unless it sat somewhere in a government reserve bunker (like my 6x18 surface grinder) will be well worn and need work. Unless restoring beautiful old machines without consideration of cost is your hobby, don't spend that much money on such an old piece of equipment unless it looks and operates perfect.
Old 11-12-2007, 11:09 AM
Gizmoavl's Avatar
Gizmoavl is on a distinguished road
kietholivier do you have a source for sheldon stuff? We ha a 20" swing 60" bed lathe that I am having a hard time finding a manual for, much less a source for parts. I found one place that has reprints of manuals on cd, but his listing shows up to a 15" swing engine lathe. I learned on a Leblond 1950's era engine lathe and this 1970's Sheldon seems to be very similar. And yes I am a hammer&indicator Dinosaur. G
GE 1050 control on Leblond lathe Kevin Taylor General CNC (Mill and Lathe) Control Software (NC) 3 02-04-2007 11:46 PM
Okuma and Leblond Jagermeister General Metal Working Machines 1 11-27-2006 01:45 AM
Leblond Makino (fanuc OM) Problem Masood Fanuc 6 09-22-2006 01:55 AM
