Old 08-31-2007, 12:24 AM
vacpress is on a distinguished road
any recent advances in DIY toolchangers?
hello! i am digging up toolchanger threads some more.. anyone know of any recent movement here?
i want a way to switch 2 to 8 end mills in a small laminate trimmer.. it seems really hard to make these 'ball-spring' holder that wont be horribly eccentric, and the products ive seen that work well on full size routers probably wont work so well on a 1hp laminate trimmer. but then, maybe someone has tried it?
anyone know of a smaller version of this basic concept, or other similar things that work? i remember seeing a similar arrangement sold as a quick change system for regular hand drills. it had tons of runout, but maybe someone has seen this product and has some ideas?
anyone actually tried to make a little device with a solenoid grabber and a stepper or servo to physically loosen the normal router-style collet?
thanks in advance!
Design & Development
My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
Old 08-31-2007, 08:15 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
I've been looking at this ( http://midwestrapidtool.com/ ) type of toolchanger system for a while, only as a diy project with Mach3.
Can anyone tell me how they are getting the drawbar thru the router motor, without messing up the motor?
The system looks very simple, yet very good. I'm thinking the entire system could be built for around $500.00 .
They also have an auction on ebay:
http://cgi.ebay.com/Automatic-Tool-C...QQcmdZViewItem
Old 08-31-2007, 09:23 AM
hey, thanks switcher. i am checking it out.
Old 08-31-2007, 09:33 AM
well. after looking at that, it seems the real secret is a spindle with a drawbar... that thing looks like a contraption at $1800.00, maybe at $300 it would look appealing. a $250 holder for a $150 router is not completely absurd, probably, but it isnt in my price range.
i suppose they probably take the motor and use a lathe to bore a hole for the drawbar? i suppose this isnt a totally crazy idea, but it would be allot harder with the smaller laminate trimmer, or some spindle other than that porter cable they like.
thanks for the lead
Old 08-31-2007, 09:36 AM
Switcher's Avatar
Moderator
The system I posted is more than I want to spend, I just thought the whole setup should be doable on a diy cnc machine.
Maybe I should build the cnc first?
Recent History Of Global Climate Change NinerSevenTango Environmental & Alternate Energy 14 01-14-2010 10:08 AM
Question about TTS and auto-toolchangers. digits Tormach PCNC 7 02-01-2007 06:13 AM
configure axis with different advances dfv Mach Software (ArtSoft software) 2 07-06-2005 05:20 PM
recent work owhite Laser Engraving & Cutting Machines 7 04-11-2005 12:15 PM
Some recent work - NON CNC Hack WoodWorking 3 01-07-2005 01:58 PM
