Old 08-28-2007, 10:57 AM
prelude1911 is on a distinguished road
Stagger Thread Cutting on Fanuc O-T???
I am trying to cut a 4-4NH thread on a Femco Durga 25-E with a Fanuc O-T control. The thread is about .157 deep per side and when I use straight threading cutting on one edge the load is too heavy and the tool breaks. I am trying to use stagger thread cutting but can't find the way to do it. I did it on a seicos control using G76 but I check the fanuc book and doesn't say. The material I am cutting is 304ss. Major Diameter is 5.000" and minor diameter is 4.686" The depth cut is only about .005" per pass. Any help is appreciated. Thanks!
Old 08-28-2007, 12:57 PM
John3 is on a distinguished road
G76 single sided
I have an 0T-B and remember wanting to do the same. I think I came to the conclusion that my controller only supported one sided cutter use in G76 threading.
You can always use G92 or G32 but they are more work.
You might try determining which revision 0T you have maybe a newer one like the -D model might do it.
John
Thread cutting in EMC mattinker LinuxCNC (formerly EMC2) 16 02-28-2007 07:24 AM
multi start thread cutting on 10TF fanuc calc G-Code Programing 5 10-08-2006 03:22 PM
thread cutting FANUC 0i TB xavierdemoura Fanuc 0 09-23-2006 08:07 PM
cutting acme thread barnesy General Metalwork Discussion 6 09-01-2006 09:06 PM
help cutting 6 pitch thread joe1970 General Metalwork Discussion 10 06-08-2006 08:43 PM
