Old 08-27-2007, 07:51 AM
Haeusser is on a distinguished road
Buying CNC mill, any advice?
Well its finally come time to start up my own shop. Im planning on buying a trak k3 mill from southwestern industries. We have one at the shop i currently work at, its nice, very simple to use. Anyone have any opinions on a better cnc 2 or 3 axis knee mill? Thank you for your time reading this.
-josh
Old 08-27-2007, 08:08 AM
Boots is on a distinguished road
The Mori Seki is a good solid Mill with low maint. costs.
Old 08-29-2007, 07:06 PM
anyone else?
Old 08-29-2007, 08:35 PM
Mickey_D is on a distinguished road
If I remember right the trak k3's are runnink around 20K. For that kind of money you could find a nice smaller enclosed vmc with a tool changer and a much faster spindle. I just saw a couple of nice Milltronics vm15s and 16s that were in very nice condition for under that price range. They would let you use flood coolant without drowning. I bought a 2 year old Sharp sv2412 for not much more than that and it is a big step up from my old bridgeport cnc knee mill. If it was me I would look for a used vmc.
Old 08-29-2007, 09:00 PM
big_mak is on a distinguished road
Buy as much as you can afford!!!!!!!! If you go cheap now you will regret it later!!!!!!
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 08-29-2007, 09:17 PM
big mak has it wrong . Buy more than you can afford! Get an enclosed VMC with full three axes.
Old 08-30-2007, 07:36 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
The Proto Trak is a great machine.
however
If you are looking to be effecient at making parts with CNC my minimum requirements are:
- Full enclosure
- ATC
- Rigid tap (unless you will never tap a hole).
Dodging chips and coolant sucks, so does cleaning up the mess on the floor.
You can get new, small VMC's starting at around $40k.
You can get decent used machines within your budget.
www.integratedmechanical.ca
Old 09-20-2007, 10:06 AM
M_Controls's Avatar
M_Controls is on a distinguished road
Cheap is not long-lasting
Listen to big mak, Geof, & DareBee. They know what they are talking about. In the long run a quality machine is worth it's weight in gold. I'd recommend Mori Seiki, Okuma, or Mazak; I rarely service these machines. They are expensive, but well worth the investment.
As for the Milltronics recommendation, you might want to see my posts:
http://www.cnczone.com/forums/showthread.php?t=27542
http://www.cnczone.com/forums/showthread.php?p=345069
Forklift advice -- what should a guy know before buying one? damae CNCzone Club House 31 06-07-2007 07:19 PM
Buying a X3, need some advice dneisler Benchtop Machines 2 06-05-2007 07:41 PM
advice on buying lathe dragons_fire Mini Lathe 3 12-29-2006 07:43 PM
Buying advice for CNC noob - CNC router Geetar-ist Commercial CNC Wood Routers 12 10-18-2006 11:54 AM
