Old 05-05-2004, 04:19 PM
sendkeys is on a distinguished road
Question Direct Drive Servo or pulleys
Old 05-05-2004, 06:16 PM
Swede's Avatar
Swede is on a distinguished road
I'm a fan of direct drive when practical. It's simply easier, less components, zero backlash. You can always use timing belts/pulleys later if you need more torque, or continue direct drive but use a bigger motor.
As a CNC new guy, I was quite surprised at just how powerful a bigger NEMA 23 was for my bench mill, let alone the 34 that does the Z. I ran my mill continuously yesterday for hours and the motors simply did not get warm.
So I vote for direct for simplicity, assuming the torque is there.
Old 05-05-2004, 06:42 PM
doug6949 is on a distinguished road
One factor to consider is the length of your screws. You want to keep them below critical velocity if possible. RBS, Thomson, etc have charts to determine how fast you can spin a particular screw. If 5tpi goes above this number then you can use 2.5tpi.
Old 05-05-2004, 06:49 PM
balsaman's Avatar
balsaman is on a distinguished road
What drives? Gecko 320's like encoders under 500 ccr.
I wish it wouldn't crash.
Old 05-05-2004, 08:26 PM
Thanks everyone
Old 05-06-2004, 05:55 AM
balsaman's Avatar
Those will work.
Eric
Old 05-06-2004, 06:06 AM
bunalmis's Avatar
bunalmis is on a distinguished road
Originally posted by doug6949
One factor to consider is the length of your screws. You want to keep them below critical velocity if possible. ....
What is the crtical velocity?
Old 05-06-2004, 08:15 AM
Critical velocity is the speed (rpm's) that corresponds to the screw's natural resonance. It is sometimes OK to go up or down past this speed but if you stay near it very long the screw will act like a guitar string. The nature of motion control dictates that you stay below critical velocity in your design.
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 11 02-13-2012 02:12 AM
Using surplus servo motors as spindle drive Swede Servo Motors and Drives 11 03-16-2008 08:05 AM
Driving a 4 pole ac servo with a 6 pole drive TommyB Servo Motors and Drives 4 04-28-2005 01:17 PM
Belts versus Direct Drive bsmith DIY-CNC Router Table Machines 12 06-06-2004 10:09 PM
R90H Servo Drive Verboten Servo Drives 16 03-30-2004 09:10 PM
