Old 08-21-2007, 10:10 AM
saacengineering is on a distinguished road
Unhappy problems with ATC on mitsui seiki
hey all i am having problems with mitsui seiki VR3 with 11m fanuc controls the ATC doesnt work it holds 20 tools in the mag n one in spindle when i type in a command like T2 M06 it gives me an alarm it only changes tool between 2 tool number which are T6 and T11 the rest give me alarms. i tried to go into NC/PC mode and bring up the data table but the data table doesnt show any idea why the rest of the tools dont work ? HELP PLEASE!
Old 08-21-2007, 03:28 PM
nakatome is on a distinguished road
atc mitsui seiki
hi, have you tryed just calling a tool in the magazine like t1 or t2 eob cyc start dose mag turn , also what alarms are you getting , nakatome
Old 08-21-2007, 04:15 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
Try T0 M6:and see if it empties the spindle.If it does then try another tool number other than T6,T11.
Run M30 once.Sometimes that helps.
I know, it's not what you normally do but it has helped me several times when everything else fails.
Old 08-22-2007, 09:30 AM
Unhappy Atc
hey guys i tried to use T0 to empty the spindle out and it gives me an alarm the mag does not rotate, it only rotates if i call tool number 6 or 11 if i jsut call T0 or T04 or any other number it gives me an alarm the mag does not rotate oh and M30 did not work plz help with more advice thank you
Old 08-22-2007, 12:42 PM
Take a look at the sensors.The ATC may be in the right place but the sensor doesn't detect that.Most of them have a little diod(red or green).It should be lit up when affected.
This is what they can look like.
Old 12-31-2007, 10:12 AM
TIMOTHYDONALD is on a distinguished road
i have the same machine and the same problem.
when i call t3 m6 nothing at all no alarm.
do you know if there is a sub program in the memory O9001,or O9000
to make tool change.
Old 12-31-2007, 02:36 PM
Yes, you should have a sub program for tool change.My program is O9029.
Stefan Vendin
Old 01-01-2008, 05:41 AM
ATC
the way i solved my problem was by resetting the ATC data table in NC/PC mode. It tends to get corrupt every so often, my sub programs worked fine but the problem was in my data table it gets corrupeted if u dont have ur memory protect on or press ATC button after the inital start up. if you need the data table i have it, you can try to reset it see if that works, on my machine i have to reset the pramaters every month or so.
Old 01-02-2008, 11:33 AM
is it possible to get a copy of that program.
thanks tim
Old 01-02-2008, 10:23 PM
sub program
hey i have all the subprograms if you need them, just email me @ saacengineering@gmail.com and i will send them to you asap and my machine is a 1985 VMC VR3 with fanuc 11m
  #11   Ban this user!
Old 07-29-2010, 04:53 AM
mihai.aleonte is on a distinguished road
I have also ATC problems with a mitsui seiki VS 3A F116 1988 Fanuc 10M, i need the sub program for tool change, and what should i do next after loading the sub programs so that the ATC starts working? Should i do some changes in the data table also? What kind of?
Mitsui Seiki Fanuc 15MA PMC backup figeacaero Fanuc 4 12-30-2011 09:07 AM
Mitsui seiki VS3A ARIF AHMED General Metalwork Discussion 0 07-30-2007 01:33 AM
Cnc Milling Problem (mitsui Seiki- Yasnac Mx1) le_hungvn General CNC (Mill and Lathe) Control Software (NC) 0 11-16-2006 02:44 AM
Jasnac MX1 Control Help! Mitsui Seiki Cnc Milling. le_hungvn General CNC (Mill and Lathe) Control Software (NC) 0 08-30-2005 09:25 AM
