Old 08-17-2007, 02:55 PM
kesparate is on a distinguished road
deep drilling 2mm holes
i'm having some trouble deep drilling some 2mm holes in a2. the cut begins at a depth of 1.2 inches and goes to 1.7 inches, to the start depth there is a 2.8mm hole. the trouble that i'm having is that the drills are just snapping off. i've run them at 1200rpm and a feed a 4., 2.5, and 1. inches per minute with a peck of .03, .015, and .001 respectively. i am using cobalt drills, some with and over all length of 2., and some that are oal of 4. i don't have anything in the middle.
any recommendations? thanks for helping.
Old 08-17-2007, 03:13 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
If you have coolant through spindle,use a Regofix (or similar) ER collet chuck.
It makes a big difference.
Old 08-17-2007, 03:16 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
drill the 2 mm hole first , chances are the chips aren t coming out and are packing back into the hole
Old 08-17-2007, 03:43 PM
coolant through spindle. that remains a dream. i've only got a 7k spindle...
dertsap. that's an interesting point. i was trying to minimize the amount drilled, but if the chips aren't clearing i'm shooting myself in the foot. how do i avoid huge wander in the drill if i have so much hanging out? perhaps .1" deep 2.8mm just to have something to follow.
Old 08-17-2007, 04:34 PM
dertsap's Avatar
Gold Member
if you use a .03 peck and the proper speeds and feeds for the material your cutting ,then wander shouldn t be an issue
Old 08-17-2007, 04:53 PM
roundman is on a distinguished road
We found that at times the drills we used were very bent and so it obviously would break. We used coolant lines right on the drill and came out of the hole with each peck. Straight drills always do better.
Old 08-18-2007, 11:53 AM
Gold Member
Caprirs is on a distinguished road
1200rpm on a 2mm drill sounds pretty low to me even in A2. If you wanted to keep your SFPM down to 100, you'd need ~4700rpm. My opinion is you're not spinning the drill fast enough to help the chips up the flutes.
Old 08-22-2007, 04:14 PM
i tried drilling the 2mm hole first and kicked the speed up a bit and got very good results. thanks for all your advise.
i would have gotten back sooner but while working on this problem some other job got much hotter, and it had top wait.
Old 09-15-2007, 11:14 AM
Webderland is on a distinguished road
Talking try better coolant
also if your coolant goes bad and has a fowl smell it could be attributing to the problem
Old 09-16-2007, 12:57 AM
big_mak is on a distinguished road
A suggestion would also be to drill a 2mm started hole witha stub drill first, then go in with the longer drills. This will help get the holes in the right position
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Drilling deep 1/2" holes? lukaslouw General Metalwork Discussion 10 07-29-2008 10:08 PM
deep drilling small holes in aluminum Fremont Dave General Metalwork Discussion 13 11-25-2007 02:03 AM
Deep holes in 6061 racerdog General Metalwork Discussion 12 06-17-2006 03:09 PM
circular interpolation of small deep holes rchprks General Metalwork Discussion 9 11-25-2005 09:37 PM
Drilling deep holes. HSM Joe Machine Problems, Solutions , Wireless DNC, serial port 7 05-13-2003 01:14 PM
