Old 08-17-2007, 08:08 AM
nicolae is on a distinguished road
Cincinnati Milacron
Hello,
We have CINCINNAT MILACRON machine horizontal centers T30 with ACRAMATIC 950MC computer numerical control end
Servo drive SIEMENS model 6SC61 (4 axis).We had a power outage and after turn ON the control and hydraulics all axis moves in one time with various speed, without command.
I checked cables between motors and PWM, power output cables, cables for rotor position and tacho signals I doing commissioning by battery box but
drives runaway. I tried to adjusted drift but nothing. In this time touch pads for select axis is inhibit (power feed panel); just X touch pad is illuminated but not work.
On the power feed panel have illuminated just X, CONT, 100% touch pads LED’s all the time.
Can you help me please?
Thanks!
Old 11-25-2007, 05:02 AM
gridley51 is on a distinguished road
Is it a 610 or a 611?
Mike you might get a bit of business if you helped people rather than spamming us with you details.
Mark.
Old 12-14-2007, 08:49 AM
bsiniard is on a distinguished road
M-Codes
Does anyone have a copy of M-codes they could email me? I grew up on Fanuc and am now setting and running Cincinnati and I am desperate for a copy of m-codes for Acromatic controls,thanx
Brad
bsiniard@sbcglobal.net
Old 12-14-2007, 04:55 PM
NC Cams is on a distinguished road
"Runawa;y" (the original problem) is caused when the feedback loop collapses or is interrupted.
Simply "checking the cables" may not be adequate. Is there signal coming and going? Is there power on/to the cables? (the encoders need and use power).
The "problem" is probably going to be best solfved by a logical process of finding and/or elimination.
FIND if you have what you're supposed to have at various places (signal, power, feedback, etc). FIX what is not there. When you look hard enough, ESPECIALLY AFTER A POWER INTERRUPTION, you usually find an electronic gremlin SOMEPLACE (fried ground, broken wire, hurt power supply, etc). Get out your meters and schematics and start looking at and for proper signals.
WHen you find out something that should be there that ISN'T, you'll probably find your problem(s).
Cincinnati Milacron mariusborza General Electronics Discussion 9 08-09-2010 03:24 PM
Cincinnati milacron arrow 500 shmoo General Metal Working Machines 20 06-17-2009 11:15 AM
Cincinnati Milacron controller parts Colin Vertical Mill, Lathe Project Log 7 09-01-2007 01:17 AM
Cincinnati Milacron Turning Center sc6chuck9 CNC Machining Centers 0 07-06-2007 04:13 PM
cincinnati milacron machines? any info? stanglou General Metal Working Machines 2 12-23-2006 05:52 PM
