Old 08-14-2007, 08:03 PM
teal854t is on a distinguished road
Mori NV5000 lost X,Y,Z,W zero reference
Hi
one of our Mori Seiki NV5000 mill with Fanuc 18i controller lost X,Y,Z,W(tool changer) zero reference position. I need instruction on zero referencing.
Old 08-14-2007, 09:25 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
What did you do to lose the reference positions?It's easier to help if you know what caused it.
Old 08-14-2007, 10:57 PM
Replaced battery and wasn't connected correctly. Didn't loose any parameter just the zero reference position.
Old 08-14-2007, 11:11 PM
So nothing happens when you try to "home" it?
Can you run XYZ manually?With the hand wheel?
Old 08-25-2007, 09:34 AM
CNC SERVICE is on a distinguished road
Mori Seiki Engineer
PLS CALL SERVICE CALL CENTER ASK THEM THE PROCEDURE TO DO THIS JOB(THEY HAVE PEPER LIKE I HAVE BUT MANY MANY PAGES). THEY HAVE QUITE ALOT MANY POINTS COMPLICATED, ESPECIALLY W AXIS AND Z AXIS IF YOU DO WRONG POSITION IT EASY TO CLASH A TOOL AND SPINDLE. AND YOU NEED TO CHANGE SOME PC PARAMETER TO MAKE W ZRN. I THINK THEY CAN HELP YOU IF CAN NOT GET FROM THEM EMAIL ME AT k_amnaj@yahoo.com.
THANKS.
Scripting reference... kiwichris NCPlot G-Code editor / backplotter 5 11-15-2007 04:36 PM
Good GD&T reference? pkelecy Mechanical Calculations/Engineering Design 2 11-04-2006 07:57 AM
Reference positions in DIY CNC davidp General CNC (Mill and Lathe) Control Software (NC) 4 05-23-2006 03:48 PM
Threading Reference jlv3901 General Metalwork Discussion 2 10-31-2005 03:49 PM
Programming Reference jhwatts General Metalwork Discussion 6 10-19-2005 03:37 AM
