  #13   Ban this user!
Old 08-10-2007, 01:38 AM
ckm ckm is offline
Too many projects
ckm is on a distinguished road
Originally Posted by Skyshark View Post
That's a good idea Chris - one of the great knifemakers in my industry, Kevin Wilkins, uses a Haas for his work... he was even featured in the Haas magazine recently. The thing is, my upper limit is still pretty much the same, so I can't just buy a (roughly) 10K fried Haas, then spend another 10k fixing it, you know? How much does it typically cost to replace the electronics on something like that, anyhow?
From what I have seen, it's usually the control that goes. And they are often crap on tapping centers anyway (they're ment for tapping, not milling...), so it's not like you'd want to fix them. The easy solution is to hook up something like Mach3 and use a PC to control them. If the servo drivers in the thing prove to be too much of a hassle, you can replace those electronics with Geckos.
The only really difficult thing (relatively speaking, it's all difficult) is getting the tool changer to work.... But then you would have a small, very ridgid mill for cheap that you know how to maintain at least of chunk of yourself...
That said, I'll definitely call around to the local dealers and see if they have anything like that, thank you for the suggestion.
Honestly, I'm not even sure I need a "knee" style mill - I just want something with the rigidity to cut 18" of steel when I get into that level of processing & design work.
Actually, these are not really knee style mill, they are more like a mini Haas VMC, like the one pictured. I am eventually planning on doing this, and there was one of these on eBay with blown controls for $5k. I just don't have the time or $$$ right at the momment.
Chris.
List of parts sources for CNC builders - http://www.CNCsources.net
Dyna Mechtronics 4400C Conversion - CNC bed mill w/toolchanger to Mach3 conversion - http://www.cnczone.com/forums/showthread.php?t=50787
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-11-2009 11:11 PM
3D Machining on a 3 axis vert mill broderi General Metalwork Discussion 1 04-14-2007 11:35 AM
Tired of banging my head against the wall soarnut CNCzone Club House 4 01-09-2006 12:37 AM
Mill head MrRage Benchtop Machines 4 11-06-2005 02:20 PM
I'm new here and in the research stage. would a X Y mill table be good for CNC proj? trilect DIY-CNC Router Table Machines 14 12-04-2004 05:48 PM
