Old 08-05-2007, 10:06 PM
under-dog is on a distinguished road
Demagnatizer question issues HELP!
I just purchased a demagnatizer at the local flea market. It is a model I have seen before(we had one where I used to work). Not sure what that is though.
It is a blue box about 3" x 6" footprint with a metal top whick is the demagnatizing surface.
It seems to work except after a bout 30 seconds or so it seems to shut off (stop humming and the red light goes out). At this point you do not want to touch the top because while it is not humming anymore it will discharge into your hand. I learned that the hard way.
If left for awhile longer it turns back on and the cuts out again. If unplugged and shut off and then restarted similar results.
On the side it says not to leave on or transformer will over heat.
I opened it up and everything looks to be in good shape. Nothing burnt and no loose wires or anything.
Is this normal? If not what can the issue be? I dont remember the one we had at work doing this.
It is almost as if it is over heating, cutting out and then it cools down and restarts
ID:	41772   Click image for larger version
Old 08-06-2007, 05:33 PM
NC Cams is on a distinguished road
The circuit may have a current sense/limiter built in. You know, sort of like a flasher for the turn signals. When the sensor has passed enough current, it automatically shuts down.
This is a way of building and collapsing the magnetic field which can be critical to the demag process - if you leave the device running full on, you can actually start to remag the part.
Or there may be a short which you really will want to fix....
Old 08-11-2007, 08:04 AM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
When I setup my new garage shop, I bought one fom Harbor Freight!
It too worked for a few weeks, then it went cold!
After removing the top plate, I noticed all the "Crimp Lugs" were loose!
So I broke out my soldering iron and made sure all the crimp connections were soldered strong!
Now it works every time!
Widgit
Old 08-11-2007, 10:33 AM
Al_The_Man's Avatar
If it is cutting out prematurely, I would check the operating current, also being a simple low frequency electro-magnetic device, there should be no 'discharge in to your hand', it almost sounds like you have a leakage to ground and the D.M. is not grounded properly.
Old 08-11-2007, 09:07 PM
demag
Thanks for the replies all.
Everything inside seems to be wired and connected well. It works fine for about 45 second to a minute then cuts out and comes back on after a @3o second pause.
I will have to dig deeper.
As I said it works fine when it does work and I just cant touch it when it cuts out. If I cant get it to stop what it is doing it will still work for my purposes.
Old 08-11-2007, 09:58 PM
Gold Member
Mine was doing the same thing!
First look at mine, the connections were tight, but as I looked closer, I could see the crimps were on the insulation and not the conductor! The vibrations were loostening the connections, making them intermitant!
Try soldering EVERYTHING, it can't hurt!
Widgit
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Ground issues... kolokithas Gecko Drives 9 12-06-2006 03:05 PM
Accuracy issues itsme Benchtop Machines 16 10-29-2006 02:17 PM
VTC-41 issues rond Mazak, Mitsubishi, Mazatrol 3 06-20-2006 07:25 PM
MDI & t & s issues? howling60 CamSoft Products 8 02-24-2006 11:27 AM
backlash issues camfambmw5 DIY-CNC Router Table Machines 11 09-23-2003 12:33 PM
