Old 08-05-2007, 01:10 PM
SRT Mike is on a distinguished road
Shimming lathe tooling?
Another dumb question. My LC-40 takes 1.25 high by 1.0" wide toolholders. These are a PITA to find. I also want to use positive rake tools and almost nobody makes 1.25 x 1.0" postive rake holders.
But there are a ton of 1.0x1.0 holders out there! If I shimmed them .25 I could use them. No problem doing that, right?
Anyone got a good source of shim stock? McMaster only has round ones and I'm looking more for .25 x 1.0 x 5" maybe. Ideally, if there were some short of real thin, sturdy, adjustable shim, I could use 'em on both sides of my tool and get them perfectly centered. Anyone know of anything like that?
Thanks!
Old 08-05-2007, 01:43 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Thanks!
Your in luck because MSC sells individual plastic sheets as well as complete sets from .001 to .03 thicknesses.
http://www1.mscdirect.com/CGI/GSDRVS...00000024100229
Cheers!!!!!
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 08-05-2007, 02:03 PM
You need to hold the 1 x 1 holder out as well as up. Why not machine your own L shaped spacer? Hot rolled steel would be fine and would not distort like cold rolled would when you took most of it away. You could even secure them in the holders with a flat head countersunk bolt.
Old 08-07-2007, 08:03 PM
I think the width would be ok, no? The holders in the machine are 1.0" wide 1.25" high, so with a 1.0"x1.0" holder I figured I could just shim it up?
I'll need to play with shimming anyway because from look at dat turret, its gonna need a biiiiig hammer to move it, so for now I'll shim tools until it's sorted
Old 08-07-2007, 11:19 PM
HuFlungDung's Avatar
Moderator
You can purchase precision ground flat stock tool steel bars in many widths and thicknesses. Myself, I'd likely get a bar of 1/4" x 1" C1018 cold finished flat bar to wack up.
Old 08-08-2007, 05:34 AM
eject_21 is on a distinguished road
I use .25" aluminum flat stock on top, and behind the tool to get it on center,and to get it "out" beyond the face of the turret. No need for anything fancy, shim, or shave the spacer to get on center in "X". The spacer behind will probably fall out once you get everything tight, I leave it out.(Better than it falling out and running into the face of my part).
Lathe tooling? gearsoup CNC Tooling 4 09-21-2007 01:52 PM
swiss lathe tooling help reddog37 General Metal Working Machines 36 06-28-2007 06:20 PM
Swiss Lathe Tooling? solgood General Metal Working Machines 8 12-15-2006 08:26 PM
Lathe Tooling Zumba General Metalwork Discussion 16 04-02-2006 11:35 PM
about to buy 7x lathe, help me pick out some tooling draculia Mini Lathe 6 04-02-2006 06:38 AM
