Old 08-02-2007, 06:49 AM
donl517 is on a distinguished road
Seperating Tramp Oil From Coolant??
So I have an oil skimmer on my coolant tank, but it is skimming 10 times as much coolant as oil into the collection can. What is the best way you have found to seperate the oil in the collection can from the coolant?
Thanks,
Don
Old 08-02-2007, 09:11 AM
Thanks,
Don
We have found that skimmers will pull a lot of coolant over so you have to let it settle again and have a second skimmer in the first collection tank skimming into a final collection tank. We also found if the first tank was heated, we are dealing with 50 gallon drums and use a band heater, the oil separates more effectively.
Looking for a better coolant? shawn General Metalwork Discussion 9 06-29-2009 11:13 AM
Coolant...Which and why? ajl6549 General Metalwork Discussion 15 12-08-2008 09:02 AM
Coolant or No Coolant when turning.... Crashmaster General Metalwork Discussion 3 05-20-2007 02:20 AM
Best coolant machinist39 General Metalwork Discussion 15 05-13-2006 02:25 PM
COOLANT (what are you using?) carbidecraters General Metalwork Discussion 12 01-22-2006 01:31 AM
