Old 08-01-2007, 09:05 PM
fatboy55 is on a distinguished road
t-slot
Hello All,
I have to cut a tslot in alum with a woodruff cutter tomorrow, should I conventional or climb mill?
Fatboy55
Old 08-01-2007, 09:53 PM
Pres is on a distinguished road
Rough conventional.
Finish climb.
Pres
Old 08-01-2007, 09:59 PM
Originally Posted by fatboy55 View Post
Hello All,
Fatboy55
On your first cut you cannot avoid doing both at the same time.
Also if you are cutting a tee slot you should be using a tee slot cutter not a Woodruff cutter. Woodruff cutters are only side cutting, tee slot cutters are side and face cutting. Also tee slot cutters are sized to cut standard tee slots while Woodruff cutters are sized to cut keyways for Woodruff and a very different in proportions, diameter and thickness, to tee slot cutters.
Old 08-01-2007, 10:16 PM
Yeah, I know what your talking about with the proper tslot cutters. I've never used them but are aware of the uses. I have no time to order any cutters and this is what was available. I have to make the tnuts also so I can use any size that'll work.
I'm going to make the slot wide enough for the woodruff cutter to enter the channel so I can cut only on one side, so.....conventional or climb:-)
On my little mill I always conventional mill but on my Industral Hobbies mill, MUCH bigger, I aways climb. Today I was side milling a piece of 6061 1/2 inch thick taking 1/4 inch off the end with a 3/8 end mill. Super easy on that mill even with a high feed rate.
This job is going to be done on the big IH mill so conventional or climb. Climbing is easier on the cutter and this woodruff is delicate so I would guess climb???
Fatboy55
Old 08-01-2007, 10:21 PM
.....Climbing is easier on the cutter and this woodruff is delicate so I would guess climb???
Fatboy55
Climb also can give better chip removal which is going to be a problem. Go very slow to start, it is easy to wedge chips in the teeth of a Woodruff cutter and things go downhill quickly when that happens.
Old 08-01-2007, 10:38 PM
Good point Geof. Thanks. Lucky for me this project can be made many ways and doesn't have to be pretty. If I do $#%@ it up I can always just cut the main slot as wide as the tslot was going to be and bolt some bar stock down to "make" the t slot. I might even mill a pocket so it's all flush.
Thanks again for the advice. It seems to me that if the mill is stiff enough climb for everything. Are there any exceptions? I bet there are but I have not run into one yet.
Of course on my little mill I can only climb for finish cuts. It can't handle deep climbs.
Fatboy55
Old 08-01-2007, 11:03 PM
....It seems to me that if the mill is stiff enough climb for everything. Are there any exceptions? I bet there are but I have not run into one yet....Fatboy55
I seem to recall reading someplace that conventional milling is better for tough materials but that does not make sense to me because the prolonged cut entry of conventional milling I would expect to be more difficult with something that was tough.
I cannot think of any reason to not use climb milling if the machine is capable of it.
Old 08-02-2007, 01:45 PM
Andre' B is on a distinguished road
On materials with a hard skin like iron castings or case harded parts.
The cutting edge last longer with conventional milling on the first pass.
Old 08-02-2007, 01:50 PM
Yes. So the exception count is now 1.
Old 08-02-2007, 06:28 PM
I knew there would be, always is!
Fatboy55
Coated Carbide 4Flute Endmill, 3Flute Slot Drill, or 2Flute Slot Drill? weaston General Metalwork Discussion 7 04-11-2007 10:00 PM
T-Slot dafowfidy Syil Products 2 02-24-2007 03:28 AM
T-Slot tables coolman DIY-CNC Router Table Machines 3 05-26-2006 02:30 PM
T-Slot Table georgebarr DIY-CNC Router Table Machines 11 12-07-2005 08:37 AM
