Old 07-31-2007, 12:51 AM
chevdrgtrk is on a distinguished road
Can't find a timing pulley
Anyone know where I can get a metal .375L pitch timing pulley with 40 teeth, and a .625 bore with a 1/2 wide belt? I have found them in plastic, but I'm not to sure if it will hold up to the forces it takes to drive the knee.....I have found all the other pulleys I need in metal. I am wanting to drive the X&Y 3-1, and the knee 4-1.
Old 07-31-2007, 01:50 AM
roonster71 is on a distinguished road
try www.misumiusa.com they may have it but its a .63 bore
2006 inch catalog page 297 ive used them b4 there very helpful on the phone and there prices are resonable to
Old 07-31-2007, 10:50 AM
vulcom1 is on a distinguished road
I live in the Great white north so may have a different supplier but yesterday a gentlemen gave me the Gates catalouge. From what I understand you need part number :TL40L050, product number: 7881-7054
which is 40 tooth, grey iron pulley. The bore range is .5" to 2.125 in. If you have a Gates belt supplier he should be able to order that and your adapter.
John
Old 07-31-2007, 12:15 PM
Tim Bailey is on a distinguished road
Try Mcmaster-Carr
They have a large selection of belts and Pulleys. You might have to bore the 5/8 hole or buy one with a QD bushing (taper lock bushing
Tim
Old 07-31-2007, 01:15 PM
rustamd is on a distinguished road
check out econobelt.com
They seem to have 41 of those with double flange in steel.
What is a timing belt and pulley ? ynneb FAQ of CNC Machine building 2 02-18-2011 07:38 AM
bridgeport timing pulley dgalaxy Bridgeport and Hardinge Mills 4 02-19-2008 04:41 AM
HTD timing belt pulley R.thayer General CAM Discussion 1 02-03-2007 01:42 AM
Timing Pulley Question SPEEDRE Mechanical Calculations/Engineering Design 10 12-24-2006 10:46 AM
Turning a timing pulley bgolash General Metalwork Discussion 9 03-21-2006 09:14 PM
