Old 07-21-2007, 12:56 PM
SRT Mike is on a distinguished road
Broken lube line - how to make new one?
This may be a dumb question, but I got my Okuma LC40 last week and I was going through the major systems prior to starting to use it - discovered it was not lubing right. I have tracked this down to a broken metal lube line inside the pump that goes from the pumping mechanism exit hole to the fitting on the outside of the pump housing that connects to the machine lube lines.
It's a small bent metal hose with a flange fitting that I am not familiar with. It's a brass-colored collar that is crimped around the end of the line maybe 1/8" from the end. I know how to do brake hoses, but I am not familiar with this kind of flange.
Can I buy the line and a flanging tool to put these little brass collars on? Or do I need to buy a whole new pump assembly?
Thanks!
broken tap T.L.A.R. eng General Metalwork Discussion 21 02-24-2007 06:38 PM
Deskengrave broken macona General CAM Discussion 2 01-08-2007 04:58 PM
Need some advice / help on broken off bolt. Ace12GA Mini Lathe 12 09-08-2006 05:44 PM
Broken Mill help avsfan733 Bridgeport and Hardinge Mills 9 11-15-2004 12:17 PM
Com Port Broken?? ARB General CAM Discussion 9 06-24-2004 04:29 PM
