  #13   Ban this user!
Old 08-14-2007, 09:51 PM
stustev is on a distinguished road
Have a look at
www.linuxcnc.org
This would be a very good learning project for the students. They could do the retrofit and then make parts.
All at the right price. The software is free. The computer can be very cheap. A parallel port could possibly have enough I/O's. If not a second parallel port card is very cheap.
Stuart
  #14   Ban this user!
Old 08-15-2007, 07:18 AM
NC Cams is on a distinguished road
Lathe retrofits are NOT plug and play projects and just might a bit much for the student.
Even seasoned pro's have had "issues" with professionaly sourced lathe retrofits - especially old, machines whre you try to re-use the factory fitted servo motors.
Having tried to look into doing a lathe retrofit on a servo equipped Fanuc 5T lathe, I can say that it is NOT as easily doable as a mill retrofit.
Do a "lathe retrofit" search on CNC Zone and you'll see some of the less than satisfying experiences that others have in this area. In all fairness, there are folks who have had good luck retrofitting lathes. I just haven't run across any who did so on machines like those I was looking to retrofit (servo fitted, late 70's/early 80's dated Fanucs)
  #15   Ban this user!
Old 08-15-2007, 12:58 PM
From the tone of these posts it looks to me like a retrofit will be just as easy if not easier than trying to get the original plc and ic's working. At least there is current support for a retrofit.
Old 08-15-2007, 02:41 PM
Al_The_Man's Avatar
Originally Posted by stustev View Post
From the tone of these posts it looks to me like a retrofit will be just as easy if not easier than trying to get the original plc and ic's working. .
Not neccessarily, it depends on the current condition and options the lathe has.
Remember all the motor integration and tuning will be done. The operator Panel should all be there with Handwheels and features.
He may not get all the options he has in the machine at present if going with a a parallel port controller.
If I read his post right, All it needs is a suitably sized PLC, these can be had on ebay for 100~200
It just requires someone with a little expertise in the PLC area.
As that great statesman G.W.B. once said, 'It's Not Rocket Surgery'
AL.
  #17   Ban this user!
Old 08-15-2007, 03:09 PM
I am just trying to suggest options.
Old 08-15-2007, 05:13 PM
Al_The_Man's Avatar
I think that is what we are all doing, pointing out the pros & Cons.
Restarting in mazatrol program Castle1 Mazak, Mitsubishi, Mazatrol 16 07-03-2007 06:43 PM
Restarting a job half way through after PC crash cpcp Mach Mill 9 04-16-2007 01:03 PM
Stopping and Restarting in a Program Dugg Haas Mills 5 01-14-2007 03:32 PM
Restarting an EIA subprogram ajl6549 Mazak, Mitsubishi, Mazatrol 6 08-09-2006 06:06 AM
restarting in mazak Jnicely Surfcam 1 02-22-2006 08:21 PM
