Old 07-18-2007, 06:59 PM
dodgy74 is on a distinguished road
Shizuoka with Bandit Quickdraw Cover help
Hello all,
I've recently purchased a Shizuoka ST-N with a Bandit Control and Quickdraw. I'm in the process of cleaning the entire machine and am making new control panels for it. Problem I have is I have no idea what all of the buttons/switches do. Does anyone have a picture or know what all of them are for? I'm attaching a couple of photo's to show what I'm talking about. Any help at all would be really appreciated!
Thanks,
David
Sorry for the bad photos but I only have a camera phone right now.
ID:	40882   Click image for larger version
ID:	40884   Click image for larger version
Old 07-18-2007, 09:07 PM
HuFlungDung's Avatar
Moderator
I can take a photo of the front panel for you tomorrow.
Do you have all the circuit boards that belong inside the toolchanger? It looks empty inside and that is pretty ambitious to just pull all that stuff out, unless you made a good road map first
What did you pay for that, if you don't mind me asking.
Old 07-19-2007, 03:09 PM
Moderator
Note,
Your toolchanger has two extra white pushbuttons on the front. I will hazard a guess, that those would have been for an rpm changer motor, which would have been used to automatically change the setting of the variable speed sheave. I never had an rpm changer, but when I converted from Bandit to Shadow, I went with VFD drives.
Old 07-19-2007, 05:14 PM
Thank you!
Hey Dung Flinger,
Thanks for the photo! To answer your questions... I have all of the parts for it in a box and a schematic so I think I'll be able to figure it all out. I know that the machine worked prior to being disassembled and have some electronics experience so I don't think it'll be a problem getting it going again. It is however my first mill and have read many of the horror stories in regards to the Bandit so I'm hoping to not run into too many problems.
I paid $3000 usd for it. I don't know if that's good or bad but it seemed like an okay deal to me. The machine is quite dirty but is in very good working order as far as the mechanics go.
I think you're right about the RPM changer. In the pic of the whole machine you can see the RPM motor sitting on the bed of the mill and the wiring goes into the tool changer.
Thanks again for the photo. I'll be sure to share some pictures as work progresses.
Cheers,
David
Old 07-19-2007, 05:19 PM
billystein is on a distinguished road
that brings back memories.
i do know that the drawbar motor can be replaced with an electric impact wrench with the handle cut off. black and decker i think.
Shizuoka Cnc An-s SHIZUOKA CNC Tooling 3 10-27-2011 12:15 PM
Shizuoka B-3V help petek General Metal Working Machines 2 04-19-2007 11:01 AM
Shizuoka help petek Test Forum 0 04-18-2007 12:28 AM
Bandit CNC machine the General CNC (Mill and Lathe) Control Software (NC) 0 08-23-2006 03:22 PM
Shizuoka cnc mill retrofit cbucner Vertical Mill, Lathe Project Log 45 08-03-2006 05:05 PM
