Old 07-18-2007, 12:11 PM
Crashmaster's Avatar
Crashmaster is on a distinguished road
Question Bar Pullers for CNC Lathe
I run a CNC lathe and am interested in purchasing a manufactured bar puller. Up to this point I have fabricated a crude system that works decently enough. My question is is that I have seen these bar pullers on MSC for upwards of $600. Has anybody used these? Are they worth the money or am I better off continuing to make my own?
Old 07-18-2007, 01:37 PM
For what it is worth we always made our own pullers until we had the time to build hydraulic barfeeds for all our machines.
When you are pulling you are parting-off so we simply made pullers that would gripp in the part-off groove. The sequence was to part about 50 to 100 thou deep, change to the puller which was made to fit the parting groove and pull out the bar then go back to the part-off and finish the parting.
Old 07-18-2007, 04:33 PM
M-man is on a distinguished road
Hydralic barfeed? I ve got the luxery to have servo... There are pullers that are attatched to the parting off tool. Check the web.
Old 07-18-2007, 04:42 PM
Maybe you can answer a question. For the servo barfeed to advance the bar is it necessary to stop the spindle or can it be done while the spindle is running?
I know about different kinds of pullers; some are spring grip, some operate by coolant pressure or air pressure. We just found it easier to make our own style.
Old 07-21-2007, 05:03 AM
We always stop the spindle during advance, but it is possible to rotate spindle if you rebuilt the pusher with a bearing at front..
Old 09-05-2007, 06:58 PM
DJPdesign is on a distinguished road
M-man, can't find the parting off tools that act as pullers, can you point me in the right direction.
Dan
Old 09-05-2007, 07:14 PM
Dan
It is a puller thto the parting tool holder.
http://www.dunhamtool.com/cnc_lathe_bar_puller.html
http://www.barpuller.com/
http://www.mmsonline.com/articles/0107rt1.html
Put 'lathe bar puller' in Google
Converting my Engine Lathe to an 8-Station Turret Lathe! widgitmaster General Metal Working Machines 93 10-31-2011 04:27 AM
cinturn lathe with an acramatic lathe PETE1968 Mastercam 18 10-15-2008 09:37 PM
Lathe Comparison - Best small lathe for CNC acondit Mini Lathe 48 03-23-2006 08:10 PM
Anyone have a mini cnc lathe or medium sized cnc lathe nymachinist Mini Lathe 6 01-23-2006 09:36 PM
New Micro lathe built by me (my second lathe) Stevie General Metal Working Machines 15 11-03-2004 04:56 AM
